Sun Sep 18, 2022 11:34 pm
px 125 disc
px 125 disc
Sun Sep 18, 2022 11:34 pm linkquote
My fuel gauge was always reading on the low side( never more than showing 1/3 full).
Took the float unit out and discovered the float had fuel in it.
Decided to try and fix the issue so I drilled a small hole in one end and drained the excess fuel out, resealed the float carefully with a small soldering iron.
I was unable to find any obvious hole where the fuel might have got in so I ran the soldering over the seam on the float to reseal it, hoping that was the issue.
A month later the float is still working fine.
Tue Sep 20, 2022 6:47 am
Tue Sep 20, 2022 6:47 am linkquote
They get brittle and rot over time. When you take them out you almost feel it could shatter if you dropped it.
Tue Sep 20, 2022 1:51 pm
PX150E
PX150E
Tue Sep 20, 2022 1:51 pm linkquote
That is exactly how I have repaired them in the past. A tiny hole usually develops right at the seam, and if you squeeze the float in the middle with your fingers, you can see fuel squirt out of the hole. I have tried to substitute the float with a similar size plastic Aspirin bottle; it works, but the fuel eats and melts the plastic in short order. Another option is a champagne bottle cork, but again, fuel gets absorbed in it, and it crumbles to bits.
Tue Sep 20, 2022 11:50 pm
px 125 disc
px 125 disc
Tue Sep 20, 2022 11:50 pm linkquote
And it seems you can't buy the floats on their own, it's the whole unit or nothing
Wed Sep 21, 2022 12:59 pm
PX150E
PX150E
Wed Sep 21, 2022 12:59 pm linkquote
The fuel sending unit originally installed on PX is available below but not that cheap:
https://www.scootermercato.com/Scooter-Parts/Gas-Tanks-and-Parts/228090
However, I have obtained an old one from an old '80s Fiat that I used to have. the actual float is nearly the same and can be fitted to the scooter sending unit. In fact, that is what I have had on mine for the last 20 years, and, so far, it is still working.
Wed Sep 21, 2022 1:28 pm
Wed Sep 21, 2022 1:28 pm linkquote
You can buy them readily in the uk, beedspeed have them as do all the other good uk sites. They are about 70 quid . As like all parts , nothing cheap anymore . Paid 10 quid for a genuine delorto pilot jet, used to be a couple of pounds. Sign of the times. I don't dick about with cheap parts or cobbled together bits, just buy genuine NOS if not available .
  DoubleGood Vespa Design
[ Time: 0.0258s ][ Queries: 5 (0.0061s) ][ Debug on ][ 211 ][ Thing One ]
