Thu Sep 22, 2022 4:14 am
LX150 2V model 2011
LX150 2V model 2011
Thu Sep 22, 2022 4:14 am linkquote
Good day, sounder if anyone could assist please. Looking for the valve spring size for the above mentioned model. My scooter has broken a valve spring, would like to replace with a high performance spring set. If measurements are available then would be able to source parts, or any link where I would be able to obtain. Thank you. [/img]
Thu Sep 22, 2022 2:22 pm
Thu Sep 22, 2022 2:22 pm linkquote
OD is 17.8mm
34.3 height
19.5~19.7 compressed
wire diameter is 2.6mm
I couldn't test the rate because my tools won't work with that size.
stock uses two springs
there is a small amount of area on the base that you might be able to machine for a slightly larger spring, but honestly I wouldn't recommend it.
Thu Sep 22, 2022 2:25 pm
LX190 Friday afternoon special, Primavera, some pushbikes
Thu Sep 22, 2022 2:25 pm linkquote
What makes a spring high performance?
Thu Sep 22, 2022 2:52 pm
Thu Sep 22, 2022 2:52 pm linkquote
weight, construction material, design and machining processes: heat treat, stress relief, closer tolerances.
Thu Sep 22, 2022 6:53 pm
Thu Sep 22, 2022 6:53 pm linkquote
Pozzo,
Have you looked at Indonesian sites like Tokopedia and Bukalapak? The language is almost identical?
Thu Sep 22, 2022 8:09 pm
LX150 2V model 2011
LX150 2V model 2011
Thu Sep 22, 2022 8:09 pm linkquote
Wow thank you for the assistance, appreciate it. Will look at the options I have for the performance ones. No haven't looses at the Indonesian sites at all. Will do.
  DoubleGood Vespa Design
[ Time: 0.0264s ][ Queries: 5 (0.0058s) ][ Debug on ][ 211 ][ Thing One ]
