Thu Sep 22, 2022 6:35 am
Thu Sep 22, 2022 6:35 am linkquote
This isn't scooter related, but MV is the place to go for expert advice on all kinds of topics.
I have a Samsung color laser printer (model CLX-3305FW) that's worked well for years. Lately, it's been reporting "Paper jam in tray 1" and refusing to print. There really isn't any paper jam -- I suspect there's just a dirty sensor somewhere. After a number of times pulling out the paper tray and opening & closing the rear access door, sometimes it does print.
Does anyone have any advice on what type of places I could take this printer for repair? "Geek Squad"? Or some other office equipment service place? Any advice on trying to repair this myself? Thanks in advance for any ideas.
Thu Sep 22, 2022 6:56 am
Contributor
2007 LX 150 (memories)
Contributor
Thu Sep 22, 2022 7:05 am
Thu Sep 22, 2022 7:05 am linkquote
Thanks, NightWing, that's the kind of answer I was looking for. I'll give it a try.
Thu Sep 22, 2022 9:46 am
2018 Vespa 300 GTS Touring
Thu Sep 22, 2022 9:46 am linkquote
I would suggest using compressed air to blow out dust bunnies etc through the printer innards. If you are going to wipe anything down instead of using windex or water based solutions, I would suggest using isopropyl alcohol, as it will evaporate faster and you don't want moisture sticking around.
Thu Sep 22, 2022 10:18 am
Thu Sep 22, 2022 10:18 am linkquote
I tried that, including use of isopropyl alcohol. No luck. I also tried a different brand of paper.
Thu Sep 22, 2022 9:10 pm
GTS300 Super (Heinz) GTS250 Super (Bulger)
Thu Sep 22, 2022 9:10 pm linkquote
Nightwing's answer is very good. if there is a roller kit available buy it. If not, at least clean the ones you can reach.
Thu Sep 22, 2022 9:45 pm
LX190 Friday afternoon special, Primavera, some pushbikes
Thu Sep 22, 2022 9:45 pm linkquote
PM Monogodo. He's the printer guy.
https://modernvespa.com/members/monogodo
Fri Sep 23, 2022 8:24 pm
Reprehensible Misinformant
Fri Sep 23, 2022 8:24 pm linkquote
Samsung sold their entire printer biz to HP a few years back, HP is killing it in favor of HP branded gear (of course).
On the very off-chance you CAN find parts for what is now a white elephant device, in a supply-chain strangled industry, dont.
It's had a good run sounds like, time to move on.
Sat Sep 24, 2022 8:39 pm
Sat Sep 24, 2022 8:39 pm linkquote
Nice seeing you, gogogordy!
Tue Sep 27, 2022 11:55 am
Tue Sep 27, 2022 11:55 am linkquote
Fixed! Wouldn't you know...the tiniest most insignificant piece was causing the error! Following a YouTube video, I replaced a tiny, worn-out, rubber pad in the solenoid that engages the paper pick-up roller. A bit of an old bicycle tube, a drop of super glue, and an afternoon was all it took.
Tue Sep 27, 2022 2:37 pm
Tue Sep 27, 2022 2:37 pm linkquote
Well done!
  DoubleGood Vespa Design
[ Time: 0.0292s ][ Queries: 7 (0.0054s) ][ Debug on ][ 211 ][ Thing One ]
