Primavera 50
Primavera 50
Anybody have handy the torque specs for the smaller (modern) sprint variator nuts and clutch nut?
@californiacruising avatar
2015 Sprint 150, 2018 GTS 300
My Haynes manual doesn't have 50cc bikes
****Different bike than yours, ***yours maybe different specs
Not sure the year but
Try around 106:50 in the video
@abner_bjorn avatar
@abner_bjorn avatar
Have you removed them yet? Put a sharpie line through the shafts and nuts, When you put it back together, go slightly past the line. My 50cc Yamaha calls for 25ftlbs on the variator, and 30 on the clutch. Another option is to take your torque wrench and test for spec before you dissamble. Set it at 25ft lbs, try and tighten down the variator nut. Does it click before you move it? If not, set it at 30, and so forth.
[ Time: 0.0256s ][ Queries: 3 (0.0034s) ][ Debug on ][ 313 ][ Thing One ]
