Hello everyone, here i am again. I have a very weird problem with the mp3. Maybe someone recognizes this or has had it. I noticed it all of a sudden but I think the problem came gradually.
When I use the rear brake, the engine cuts out. This only happens when I have almost come to a stop. If I'm just driving and I use the brake it doesn't cut out. It happens even when I use the foot brake. I can only squeeze the front brake as hard as I want but then it doesn't cut out. Sometimes when I use the rear brake to come to a stop, you hear it want to stall and when I squeeze it, it crashes. I've been through a lot of crazy issues with it but this one is really a mystery. I already checked if that pin of the asr\abs is not good but everything looks good. now it's still quite dry it doesn't give much problems but in wet or cold weather I want to come to a stop with the rear brake and not with the front.
