![]() 2008 MP3 500, 2013 BV350, 2020 Vespa Sei Giorni, 2008 Vespa S150
Posts: 8872 Location: Ashburn, Va. Home to the Internet |
![]() Fri, 07 Oct 2022 20:04:38 +0000
Vespa C38 - S50 4T Super.
Posts: 75 Location: Netherlands |
![]() Vespa C38 - S50 4T Super.
Diesel oil is often used in larger motorcycle engines, whose owners have small budgets. It usually fulfills all the requirements in the JATO oil standard for motorcycle engines. That standard is mostly so the oil will fully lubricate the engine, while not making the wet clutch slip.
I have yet to hear of serious issue those owners have run into with use of diesel oil. It is doubtful if using diesel oil in the small engines in scooters is worth it. Scooters rarely use much more than an a quart, or a liter, of oil so the price difference is negligible. They don't have wet clutches so you don't need the additives for that. |
![]() The Hornet (GT200, aka Love Bug) and 'Dimples' - a GTS 300
Posts: 42065 Location: Pleasant Hill, CA |
Sat, 08 Oct 2022 00:13:07 +0000
T.S.Zarathusra wrote: They don't have wet clutches so you don't need the additives for that. Those that *do* have wet clutches (BV350 etc) don't share the same oil as the engine. </pedant> |
![]() LXV 150 3v ie. Midnight Blue (Sold) Now Honda Zoomer X
Posts: 3873 Location: Kingdom of Lanna |
Sat, 08 Oct 2022 05:26:53 +0000
Shell Rotella as an example is fine for scooters with dry clutches. Nothing to do with its price. It has all the lubrication properties necessary. MB specific scooter oil would be better?
Not sure about all motorbikes although it does comply with JASO MA. |
Sat, 12 Nov 2022 19:14:30 +0000
I used T Rotella for 100,000 kms on 2 VStroms and it was fine, but I've not even considered it for the BV350. As you say the intervals are long and the volume small, so why not stay with the factory recommendations?
Shirker |
![]() 2020 Liberty 150, 2020 MP3-500
Posts: 507 Location: Reno |
Mon, 14 Nov 2022 17:12:49 +0000
Non detergent is important for any wet sump motor
The crank or straight cut gears splashing through oil with detergent will cause oil to foam |
![]() GT 2.4
Posts: 8008 Location: NWAOK |
Tue, 27 Dec 2022 00:33:44 +0000
waspmike wrote: Shell Rotella ... does comply with JASO MA. |
2015 MP3 500 ie Business
Posts: 960 Location: Belgium |
Tue, 27 Dec 2022 18:26:26 +0000
AFAIK Shell Rotella only meets the JASO criteria for wet clutch applications such as a gearbox.
Specifically, it has friction modifiers to prevent clutch chatter. Not all oils are the same, even if they have the same weight. This is especially the case on modern day engines. Example: Using a standard engine oil (even in the correct weight) will bugger up a modern diesel engine real quick because it is not a low spAsh oil to keep the oxidation catalyst and its associated regeneration devices functioning properly So using the Shell example the Rotella would be harmful to a modern day diesel that has SCR (Selective Catalyst Regeneration). For engines with SCR, Shell ECT in the correct weight would be the correct choice. And in case you're thinking "but this does not apply to gasoline engines", it is already being put into a few of the latest cars and will come to motorcycles as well. Just you wait. https://www.shell.com/motorist/oils-lubricants/helix-for-cars/helix-fully-synthetic/shell-helix-ultra-ect-c2-c3-0w-30.html https://www.drive.com.au/news/what-is-a-petrol-particulate-filter-and-which-cars-have-them-in-australia/ |
Thu, 29 Dec 2022 18:56:20 +0000
I can't think of a reason not to use motor oil that meets the standards laid out by the manufacturer. Sure, they may get kickbacks for recommending a certain brand of oil, but you aren't bound to that brand. Just use decent oil with the specs listed by the maker.
Mon, 09 Jan 2023 18:40:24 +0000
wentwest wrote: I can't think of a reason not to use motor oil that meets the standards laid out by the manufacturer. Sure, they may get kickbacks for recommending a certain brand of oil, but you aren't bound to that brand. Just use decent oil with the specs listed by the maker. Redline on my high RPM diesel powerstroke, was 3,600 RPM. And that is a high RPM diesel. |
![]() Gilera Fuoco 500ie
Posts: 4431 Location: Netherlands Olst |
Tue, 10 Jan 2023 15:10:40 +0000
3600 rpm high ref diesel??? thats crusing for me
![]() ![]() My W903 209CDI sprinter does 4250 at trafficlights sprints redline is 5000 I'm not sure but i think my old C220 CDI did 4500 at 230km/h |
Wed, 11 Jan 2023 09:23:22 +0000
A little 4 cylinder diesel and a V8 diesel (like Ford's PowerStroke) are worlds apart.
Example: In the truck world, the rev limit on a DAF 13Liter straight 6 cylinder is around 2000rpm, and peak power and torque is around 1500rpm. The rev limit on Scania's 16Liter V8 diesel is even lower. |
Posts: 941 Location: tampa |
Sat, 14 Jan 2023 16:20:18 +0000
I have used diesel oil in high performing 4g63 motors. modified to nearly triple factory output. I was after the much higher zinc content.
I can say when the oil first goes in the engine becomes noticeably less tinny sounding. but that effect wouldnt last. thanks to that article now I got to wonder if the zinc was indeed sacrificing itself like the article suggests. |
