ET4
ET4
I replace the carter in Leader 125 and I do not know what this pin is for? Anyone know how to disassemble it?
Regards
Glaniu
@touring300 avatar
@touring300 avatar
I'm petty sure your centre stand spring hangs on this. I will let someone more enlightened tell you how it is attached.
@safis avatar
@safis avatar
Correct, it's for the stand springs and it's pressed in. Heat the area, tap it and it should come out. Else, OEM code for a new one is: 483785
ET4
ET4
Thank you guys for your help !!!
Regards
Glaniu
@nightwing avatar
Contributor
2007 LX 150 (memories)
Contributor
@nightwing avatar
What is a carter?
@safis avatar
@safis avatar
NightWing wrote:
What is a carter?
Engine cases, we usually call them "carter" in Europe…
[ Time: 0.0145s ][ Queries: 4 (0.0021s) ][ live ][ 343 ][ ThingOne ]
