@jasond4663 avatar
Gts 300 super 2013
@jasond4663 avatar
Gts 300 super 2013
Anyone experiencing rust issues on the underside of their vespa and in where the battery is housed, if yes how did you treat it? Mine is the 2013 gts300
@tszarathusra avatar
Vespa C38 - S50 4T Super.
I am trying to deal with that now.
It depends on how severe your rust is.
With surface rust you can remove most of it with a wirebrush, then paint over it with Hammerite spray paint. While not perfect solution it's better than doing nothing.
With deeper pitted rust it's better to remove the rust with a wirebrush. Then treat the surface with rust converter. Then use bodyfiller to make it smooth. Then paint over that.
If you have large rust holes I'd sell the vespa for parts (scrap it).
@jasond4663 avatar
Gts 300 super 2013
@jasond4663 avatar
Gts 300 super 2013
Thanks, pretty sure it's just surface so I'll scrape most of it off and use the wire brush then prime it then paint it. Ridiculous the rust on such an expensive scooter 😒 🛵
@dooglas avatar
@dooglas avatar
As T.S.Zarathusra suggested, use a rust converter/neutralizer such as Corroseal before priming and painting. There are a number of previous posts on this site discussing restoration of rusted areas under the Vespa frame.
And if you have rust there, you need to check inside the battery compartment, the front seam, and the inside seams
@jasond4663 avatar
Gts 300 super 2013
@jasond4663 avatar
Gts 300 super 2013
Said that in my post, the battery compartment is also full of surface rust 🛵👍
@bill_dog avatar
eeeee bip
BMW R1100RT The Problem Child Kymco Downtown 300 - I'm not the Uber
eeeee bip
@bill_dog avatar
Standard.
@nomad68 avatar
Back on a 125cc!
@nomad68 avatar
Back on a 125cc!
Bill Dog wrote:
Standard.
This ^^^
[ Time: 0.0226s ][ Queries: 3 (0.0027s) ][ Debug on ][ 313 ][ Thing One ]
