Tue, 18 Oct 2022 18:19:23 +0000
piaggio MP3 500
piaggio MP3 500
Tue, 18 Oct 2022 18:19:23 +0000 quote
Hello,
I have a Piaggio MP3 500. During a ride I get a warning light "oil" and my engine stalls. After a stop I check the oil, it is nicely level. I start the engine back and it "runs" nicely for 15 seconds later a "screeching" sound coming up...back at home I check the engine. I take out the complete vario and start the engine again, again a high-pitched screeching sound from the inside of the engine. Waited a while, tried again. The first 15 sec everything is ok, then an emerging screeching sound. Nafenoeg the oil lamp continues to burn. There is enough oil in the motor. Anyone have an idea what this could be?
Tue, 18 Oct 2022 20:38:17 +0000
2007 MP3 250ie / 2022 MP3 500HPE SA
Tue, 18 Oct 2022 20:38:17 +0000 quote
For me sounds as you oil pump is broken or something similar.
Tue, 18 Oct 2022 21:22:41 +0000
Tue, 18 Oct 2022 21:22:41 +0000 quote
yup sounds like an oil pump failure and your seizing the motor.
Tue, 18 Oct 2022 22:25:05 +0000
Tue, 18 Oct 2022 22:25:05 +0000 quote
To clarify, the oil sensor measures oil pressure not oil level. The engine may have enough oil, but still have a serious oil-related problem. This is why others are saying your oil pump may have failed to cause this.
Wed, 19 Oct 2022 14:23:22 +0000
piaggio MP3 500
piaggio MP3 500
Wed, 19 Oct 2022 14:23:22 +0000 quote
the oil pump,whats the best way to replace?
Wed, 19 Oct 2022 15:03:31 +0000
1979 P150X, 1983 P200E, 1988 T5, 1995 PX200E, 2011 Yamaha Fazer 600 S2
Wed, 19 Oct 2022 15:03:31 +0000 quote
Pretty typical, they were prone to teeth failure. You need to split the engine to replace the oil pump...
Wed, 19 Oct 2022 20:43:49 +0000
2015 MP3 500 ie Business
Wed, 19 Oct 2022 20:43:49 +0000 quote
Whatever you do, do NOT start or drive the engine any further.
Without oil pressure, the engine will self destruct and perhaps already has started to.
As was mentioned, it is a engine out and complete teardown job. Be sure to check the cylinder bore and crank for signs of damage from oil starvation (scoring, etc.)
  DoubleGood Design
[ Time: 0.0314s ][ Queries: 6 (0.0088s) ][ Debug on ][ 276 ][ Thing Two ]
