Fri, 21 Oct 2022 19:16:36 +0000
Piaggio MP3 400
Piaggio MP3 400
Fri, 21 Oct 2022 19:16:36 +0000 quote
Hi, guys,
in case of installing 500cc engine (dual spark !!!) on standard 400 bike.
how do I need to handle the coil issue?
Changing the single coil with a dual one
or
Adding an additional 400 coil parallel to the existing one?
Thanks in advance
Nir
Fri, 21 Oct 2022 20:37:29 +0000
2007 MP3 250ie / 2022 MP3 500HPE SA
Fri, 21 Oct 2022 20:37:29 +0000 quote
In my opinion, the best beat is use a dual coil, as with 2 single coils you can run in small time differences (ms) in the voltage to the sparks that are not good for the complete combustion (the idea of a dual spark). With a dual one you are sure that both spark fire exactly at same time.
My 2 cents
  DoubleGood Design
[ Time: 0.0240s ][ Queries: 3 (0.0036s) ][ Debug on ][ 299 ][ Thing Two ]
