Sun, 13 Nov 2022 09:25:59 +0000
Vespa P200E 1981
Vespa P200E 1981
Sun, 13 Nov 2022 09:25:59 +0000 quote
My dear fellas,
I am a Spanish guy living in the UK, nice to meet you all!
I hope someone here can help me, I am so stuck!
After trying to find any info about it and after being failing for weeks I just...need help.
I am trying to add a LED spotlight to my non battery P200E.
I am going to keep the vespa AC, so I have bought a AC to DC converter only for that LED. I will add a capacitor as well to avoid flickering.
Converter:
I have installed a switch for that spotlight
I am thinking about taking the power from the wire box in the "nose" of my vespa. The green cables you see are coming from the new switch and I have created a new ground as well.
I have so many questions fellas...pfff
The main one is: How can I connect my converter? I see 2 red wires to AC IN but should I connect one of them to ground? What's the best wire from my nose box to take the AC? I am confused with this ac/dc converter.
Pfff please, I need help!
Thank you very much in advance to everyone!
Hugs from the UK
Tue, 15 Nov 2022 11:50:36 +0000
Vespa P200E 1981
Vespa P200E 1981
Tue, 15 Nov 2022 11:50:36 +0000 quote
Solved!
LED Spotlight working beautifully
Tue, 15 Nov 2022 16:23:51 +0000
Tue, 15 Nov 2022 16:23:51 +0000 quote
it would be good of you to tell us how you solved it so if someone finds the thread in the future they can understand.....
Tue, 15 Nov 2022 17:03:53 +0000
Vespa P200E 1981
Vespa P200E 1981
Tue, 15 Nov 2022 17:03:53 +0000 quote
Here is how I have solved it:
Tue, 15 Nov 2022 18:04:02 +0000
parallelogramerist
parallelogramerist
Tue, 15 Nov 2022 18:04:02 +0000 quote
Did you wire in the capacitor?
Tue, 15 Nov 2022 19:00:59 +0000
Vespa P200E 1981
Vespa P200E 1981
Tue, 15 Nov 2022 19:00:59 +0000 quote
I didn't because I am using a G4 led, so it has an internal resistor and a little capacitor. If you are not using a G4 you should wire in a capacitor and a resistor to uncharge it when you switch of your light or turn off the vespa.
Wed, 16 Nov 2022 02:37:06 +0000
Wed, 16 Nov 2022 02:37:06 +0000 quote
Seeing rectifiers with internal capacitors on Amazon
Did something similar on my Allstate/Vape AC.
Worked great all Summer. Super bright LED headlight until I rode during a heatwave (110F).
Tucked the rectifier away from the headlight in the headset, but I imagine vibration shifted it a little
Lesson learned.
Wed, 16 Nov 2022 06:42:33 +0000
Vespa P200E 1981
Vespa P200E 1981
Wed, 16 Nov 2022 06:42:33 +0000 quote
Omg! Look at that!! How is that possible??
Wed, 16 Nov 2022 13:21:51 +0000
Wed, 16 Nov 2022 13:21:51 +0000 quote
Was the LED/headlight insulated from the chassis earth?
Wed, 16 Nov 2022 17:18:16 +0000
VBA1T
VBA1T
Wed, 16 Nov 2022 17:18:16 +0000 quote
Is there any fuse box on older models in order not to damage the rest of the electrical system when shit like that happens ?
Wed, 16 Nov 2022 17:24:34 +0000
Vespa P200E 1981
Vespa P200E 1981
Wed, 16 Nov 2022 17:24:34 +0000 quote
The converter melted itself. Old vespas have the head made of metal and the space is really narrow.I suspect the converter was inside the head, probably touching the metal, so during the heatwave receiving the heat from the sun directly...the plastic just melted.
Wed, 16 Nov 2022 17:34:02 +0000
Vespa P200E 1981
Vespa P200E 1981
Wed, 16 Nov 2022 17:34:02 +0000 quote
Tomorrow I am going to test something. I am going to insert my AC to DC converter on the Yellow wire, the one going to the lights and horn.
I know my horn will stop working because its a AC one, but I want to try something simple to put a BA20d LED headlight (and my spotlight). This way the conversion is 100% reversible and simple. If it works, I will buy a DC horn.
(Sorry my P200E diagram is in Spanish. Amarillo means Yellow)
Wed, 16 Nov 2022 17:44:19 +0000
Wed, 16 Nov 2022 17:44:19 +0000 quote
I connected it directly to the high beam and ground wires from the switch. Low beam wire blanked, so switch became on/off.
It fried against the headlight.
Wed, 16 Nov 2022 18:57:00 +0000
parallelogramerist
parallelogramerist
Wed, 16 Nov 2022 18:57:00 +0000 quote
Keep in mind that those inexpensive Chinese AC to DC converters are rated for 36-watt max output, 25-watt continuous output.
Wed, 16 Nov 2022 20:32:35 +0000
Vespa P200E 1981
Vespa P200E 1981
Wed, 16 Nov 2022 20:32:35 +0000 quote
How do you know that?
Is not in the product specifications.
https://www.amazon.co.uk/Converter-Reduced-Voltage-Waterproof-Regulator/dp/B0922RYXJ5/ref=cm_cr_arp_d_product_top?ie=UTF8
Wed, 16 Nov 2022 23:46:49 +0000
parallelogramerist
parallelogramerist
Wed, 16 Nov 2022 23:46:49 +0000 quote
I remember looking at the specs for the converters about 4 years ago at Superbright LEDs. I can only assume that all of the AC to DC converters that are built in China have pretty much the same specs.
https://www.superbrightleds.com/12v-ac-to-dc-converter-module-3-amps
Thu, 17 Nov 2022 01:53:40 +0000
Thu, 17 Nov 2022 01:53:40 +0000 quote
Fascinating diagram.
Completely different approach vs the American market bikes!
I don't think your test is going to work.
Yellow is the pathway to the regulator. It's live 12v or so on your multimeter with the engine running, but it isn't the source of power. Blue is power from the stator. Yellow is to the regulator, that shunts/grounds power over 12v.
"If I were you" I'd get another one of those Chinese 5A badboys and tuck it the hell away from the headlight in the headset. Saves your AC horn.
Thu, 17 Nov 2022 02:22:18 +0000
parallelogramerist
parallelogramerist
Thu, 17 Nov 2022 02:22:18 +0000 quote
derp...i completely didn't see the 5A max on Yorch1's converter. Since that's the case, then it should be plenty to handle the power of a couple LED lights. It doesn't specify what the continuous amp rating is though.
Thu, 17 Nov 2022 10:11:15 +0000
Vespa P200E 1981
Vespa P200E 1981
Thu, 17 Nov 2022 10:11:15 +0000 quote
Yes I see the blue coming from the stator to the nose box. From the nose box to the horn switch. I can not see that blue wire going to anywhere else so...from where is the headlight taking its power? I am misunderstanding something, fella.
I would like only 2 LEDs, spotlight and Headlight. Is there any way to convert both of them with only one "bad boy" converter
Thanks Ray
Thu, 17 Nov 2022 20:28:54 +0000
Thu, 17 Nov 2022 20:28:54 +0000 quote
Thanks Ray
Headlight power is the two highbeam/lowbeam (purplish/brownish) wires from the switch, which is fed by that blue at the nose.
Can't see a way around using another converter
Sat, 19 Nov 2022 09:05:46 +0000
Super
Super
Sat, 19 Nov 2022 09:05:46 +0000 quote
Do you have the video when the spotlight working? I'd like to use converter too
Sat, 19 Nov 2022 13:04:28 +0000
Vespa P200E 1981
Vespa P200E 1981
Sat, 19 Nov 2022 13:04:28 +0000 quote
I will record one for you today
  DoubleGood Design
[ Time: 0.0292s ][ Queries: 6 (0.0056s) ][ Debug on ][ 277 ][ Thing Two ]
