Sun, 13 Nov 2022 13:49:53 +0000
MP3 400
MP3 400
Sun, 13 Nov 2022 13:49:53 +0000 quote
What are the symptoms that the belt should be replaced? Is this something I should just do?
I am at about 7500 miles and I ride it fairly hard. I hear some rumbling at acceleration and my brain says that may be the drive belt. But being the only motorcycle I have had with a CVT I'm not certain.
thanks for advice and as I found out after a few posts here....opinions....lol
Sun, 13 Nov 2022 19:11:07 +0000
2015 MP3 500 ie Business
Sun, 13 Nov 2022 19:11:07 +0000 quote
Ignoring replacement of the belt time risks it breaking and potentially locking up the rear wheel.
Now imagine that scenario when you're riding at any signficant speed.
Belt service consists of belt, roller and sliders. I am still on my original rollers, but I replace my sliders with every belt change (6K mi/10K km). I suspect your rumbling is due to worn sliders.
Sun, 13 Nov 2022 21:55:07 +0000
Sun, 13 Nov 2022 21:55:07 +0000 quote
If it's due, it's due.
And, it is very normal when I change the belt on my MP3 500 that the whole transmission works smoother. Less juddery. Probably due to sanding the variator, and all the new bits that fit to OEM specs. And the new belt not being so smooth after those thousands of miles.
It's due.
Sun, 13 Nov 2022 23:44:44 +0000
2019 MP3 500 Sport
2019 MP3 500 Sport
Sun, 13 Nov 2022 23:44:44 +0000 quote
Follow the maintemace schedule. Replace the belt et al every 6k miles. You really. never want it to fail.
Mon, 14 Nov 2022 20:50:35 +0000
MP3 400
MP3 400
Mon, 14 Nov 2022 20:50:35 +0000 quote
thanks, I will get it done then. I did try to take a peek at the belt last week and followed a Youtube video but as I was loosening the cover I had oil come out and quickly retightened the cover.
I was a bit confused because I didn't think there should be oil there. Then I read it may be from the filter if it was over oiled. I did have a full service done so maybe. I just need to have a rag ready next time.
https://www.scooterwest.com/belt-variator-tune-up-kit-piaggio-mp3-400.html
This and the tool
https://www.scooterwest.com/piaggio-500-variator-holding-tool-toolp500v.html
ant tips on the install?
thanks
Mon, 14 Nov 2022 21:54:04 +0000
Mon, 14 Nov 2022 21:54:04 +0000 quote
Oil coming from the airfilter box is almost always one of 2 things
1) Engine is overfilled. The correct refill qty is 1,5Liter although Piaggio still puts the wrong quantity of 1,7Liter in its literature
2) Excessive airfilter oil. The foam filter only need to be tacky a.k.a. a light coat of filter oil. The foam should never drip.
  DoubleGood Design
[ Time: 0.0273s ][ Queries: 4 (0.0065s) ][ Debug on ][ 286 ][ Thing Two ]
