Thu, 17 Nov 2022 07:37:56 +0000
Piaggio mp3 500 2012 model
Thu, 17 Nov 2022 07:37:56 +0000 linkquote
Hi guys. Is it possible to drive a piaggio mp3 500 with defect seat sensor? If so what do I have to do? The only way to replace it is to buy a new seat!!! I wonder if I can drive it just like that. In the shop they said yes, but I wonder if it damages the bike. Thanks
Thu, 17 Nov 2022 08:31:28 +0000
2015 MP3 500 ie Business
Thu, 17 Nov 2022 08:31:28 +0000 linkquote
Use the forum search feature. Been discussed numerous times recently
Thu, 17 Nov 2022 09:12:09 +0000
Thu, 17 Nov 2022 09:12:09 +0000 linkquote
Been searching but it's so much, and I don't find the topicโ€ฆ can somebody please help? Would be nice with pictures or film too.. all is interesting, and thanks again๐Ÿ™๐Ÿป
Thu, 17 Nov 2022 19:12:15 +0000
2016 Mp3 500ie Sport
Thu, 17 Nov 2022 19:12:15 +0000 linkquote
You can bypass the seat sensor with a 3k ohm Resistor spliced in where the seat switch sensor would normally connect.
Bike brokedown
Seat switch
Q about Fuel Stabilizer & 2-stroke engines
MP3 (250) - lack of power
Thu, 17 Nov 2022 20:32:44 +0000
Thu, 17 Nov 2022 20:32:44 +0000 linkquote
Thank you so much!
Sat, 19 Nov 2022 20:24:51 +0000
Beo 50 2t, Beo 500GT, Mojito 125
Sat, 19 Nov 2022 20:24:51 +0000 linkquote
There's no even a reason to do that. Simply use "double click" instead "single" on suspension lock/unlock switch.
Sat, 19 Nov 2022 20:54:51 +0000
Sat, 19 Nov 2022 20:54:51 +0000 linkquote
Hello again, and thanks for all the advices. I have found a solution of my own; you can treat the mp3 has a normal bike, parking on the stand instead๐Ÿ‘๐Ÿป๐Ÿ˜Ž. But it works as you said also. Thanks a lot ๐Ÿ‘๐Ÿป๐Ÿ‘๐Ÿป
[ Time: 0.0216s ][ Queries: 4 (0.0025s) ][ Debug on ][ 240 ][ Thing Two ]
