Mon, 21 Nov 2022 18:03:47 +0000
Vespa lx125
Vespa lx125
Mon, 21 Nov 2022 18:03:47 +0000 quote
Help! I have a Vespa lx125 2007 plate
Want to get it up and running it has spark put a new plug in it
When you turn the ignition on the fuel pump kicks in then stops
When you go to start it keeps cranking over but nothing
When you forces fuel in to the carb it runs for a few minutes
My question is
Is the fuel pump ment to run all the time?
I seem to have fuel troubles
Also under the seat there's a fuse holder with to fuse spaces only one fuse in there is it ment to have 2?
Mon, 21 Nov 2022 20:49:02 +0000
LX190 Friday afternoon special, Primavera, some pushbikes
Mon, 21 Nov 2022 20:49:02 +0000 quote
Check the vacuum line to the intake manifold. Probably cracked.
Mon, 21 Nov 2022 22:07:47 +0000
Piaggio Beverly 300 ie - 2012
Mon, 21 Nov 2022 22:07:47 +0000 quote
My question is
On your questions:
No. Normally when you switch on the ignition you hear the fuel pump running for a few seconds and then it stops. That is normal.
If your scooter was running fine when you last used it there probably also was only one fuse in. I expect nobody touched your scooter to remove a fuse, and you say you have spark. So that is also not the problem.
When you force fuel in the carb it starts and runs for a few minutes. Probably means it runs until the fresh fuel that you forced in is consumed.
What I think is that there is nothing wrong with your Vespa.
How long was is not used?
It could be the fuel in your tank and carb is not good anymore or there is some dirt in your carb.
I would start from there. Drain the tank and clean the carb. Put in new fuel and see what it does.
Tue, 22 Nov 2022 09:00:13 +0000
Vespa lx125
Vespa lx125
Tue, 22 Nov 2022 09:00:13 +0000 quote
Thanks for the reply I will try this
The Vespa was brought as spares or repairs I didn't know much about it I've had it for 4 years now when I first got it I had it running abit then left it now gone back to it
Has fresh fuel in it but will look in to the carb also the vacuum pipe and go from there
  DoubleGood Design
[ Time: 0.0244s ][ Queries: 3 (0.0027s) ][ Debug on ][ 297 ][ Thing Two ]
