Tue, 22 Nov 2022 14:56:47 +0000
Vespa T5 classic 1994 and 1980 Vespa p200e
Tue, 22 Nov 2022 14:56:47 +0000 quote
I've just finished rebuilding a Vespa p200e 1980 engine and I would like to know how to find out what size thrust washer i need. It's the washer what goes behind the crank.
Tue, 22 Nov 2022 15:04:00 +0000
Tue, 22 Nov 2022 15:04:00 +0000 quote
This is the clutch I'm fitting what I got off BeepSpeed. Vespa Clutch Unit P200, Rally 23 Tooth 7 Spring
Product Code: BD02130
Tue, 22 Nov 2022 15:51:23 +0000
parallelogramerist
parallelogramerist
Tue, 22 Nov 2022 15:51:23 +0000 quote
If it's just a stock height clutch basket, then i would use a washer spacer that's the same thickness as the oil pump gear that would normally reside behind the clutch on an auto-mix P200.
⬆️    About 5w elapsed between posts    ⬇️
Thu, 29 Dec 2022 18:15:55 +0000
Thu, 29 Dec 2022 18:15:55 +0000 quote
I got one 3,7 and installed it yesterday but the clutch isnt working. no clutch when in gear when pulling the clutch lever.
Thu, 05 Jan 2023 07:07:20 +0000
Rally 200
Rally 200
Thu, 05 Jan 2023 07:07:20 +0000 quote
Did you get this issue sorted, and if so what was the outcome?
Thu, 05 Jan 2023 09:43:38 +0000
Thu, 05 Jan 2023 09:43:38 +0000 quote
I didn't work so I have opened up the clutch and found plants stuck together. I have soked the clutch in oil and will install the clutch tomorrow. Just waiting on my new torque wrench to come my other is broken.
Fri, 06 Jan 2023 11:14:28 +0000
Fri, 06 Jan 2023 11:14:28 +0000 quote
I've used numerous thickness washers over the years.
Did you put all the plates in the same way around?
They are concave/convex, depending on which side you are looking at, but as long as they are all the same, all should be good
Fri, 06 Jan 2023 12:25:49 +0000
Fri, 06 Jan 2023 12:25:49 +0000 quote
I contacted BeepSpeed and they advised me to use a 2.8 spacer washer. That was before I taken apart the clutch and found discs stuck together and abit of rust. It cleaned up ok and I soaked the plants and resembled it. I mailed BeepSpeed about the rust and they ask if I soaked the clutch before installing. I've got people saying to use the 3.7 not the 2.8 because that's the size of the cog for autolub p200e they are the same size.
Sat, 07 Jan 2023 14:48:11 +0000
Sat, 07 Jan 2023 14:48:11 +0000 quote
Update. The clutch is working now with the 3.7 spacer washer. Thrust washer on it. Not been out on it yet though
Sat, 07 Jan 2023 14:49:47 +0000
2007 Stella 225
2007 Stella 225
Sat, 07 Jan 2023 14:49:47 +0000 quote
Was it just dry and rusted together? Did you just have to soak it in oil and clean it up?
Sat, 07 Jan 2023 16:12:11 +0000
Sat, 07 Jan 2023 16:12:11 +0000 quote
Metal disc stuck to the cork disc. There wasn't much rust really it cleaner up ok. Next time I buy a new clutch I will take it apart and soke the discs.
Sat, 07 Jan 2023 16:43:42 +0000
Sat, 07 Jan 2023 16:43:42 +0000 quote
Always need to soak the corks. Put them in a sandwich bag, one by one while dressing in some oil and let it sit for a spell.
Sat, 07 Jan 2023 21:37:19 +0000
bodgemaster
bodgemaster
Sat, 07 Jan 2023 21:37:19 +0000 quote
Are you saying he should be a corksoaker?
Sat, 07 Jan 2023 22:11:42 +0000
Sat, 07 Jan 2023 22:11:42 +0000 quote
aaaaah
Sun, 08 Jan 2023 00:20:29 +0000
Sun, 08 Jan 2023 00:20:29 +0000 quote
  DoubleGood Design
[ Time: 0.0330s ][ Queries: 6 (0.0101s) ][ Debug on ][ 277 ][ Thing Two ]
