Tue, 22 Nov 2022 19:18:32 +0000
VBA1T
VBA1T
Tue, 22 Nov 2022 19:18:32 +0000 quote
Hi,
I realized (after paint, of course, would be too easy...) that the bracket holding the opening lever is not centered with the cutout... I guess I have to trim that...
Here is the question... I did fit a new vespa lock, I can only remove the key on lock position, if it is unlocked, the key stays in, so is the lock supposed to let the key being removed on both positions ? If not then what's the point of the lever as the locking mechanism hold the door shut meaning you cannot open the door without the key in ?
Tue, 22 Nov 2022 19:21:28 +0000
Tue, 22 Nov 2022 19:21:28 +0000 quote
Original locks would let the key out at any position. Repro locks don't, you need to lock it first...
Tue, 22 Nov 2022 20:07:41 +0000
VBA1T
VBA1T
Tue, 22 Nov 2022 20:07:41 +0000 quote
That's what I tought, otherwise what's the point of the lever !
Maybe I got a shit repro, I'm going to check what is available in better quality, and maybe buy a new door, it won't look nice with a wider opening...
Thu, 24 Nov 2022 20:40:08 +0000
150 VBB
150 VBB
Thu, 24 Nov 2022 20:40:08 +0000 quote
I'm brand new to the world of Vespas (and scooters in general) but I'm a veteran old German car restoration mechanic. I didn't like the "non-removable key" feature of the lock on my new 150 VBB either...so I harvested a same-style lock off one of my old tool boxes. Problem solved. These kinds of locks (with spring clip retainer) are super common. Mine has a slightly taller bezel, which is fine by me...and it was FREE, so...
Fri, 25 Nov 2022 07:54:28 +0000
VBA1T
VBA1T
Fri, 25 Nov 2022 07:54:28 +0000 quote
Interesting! I might have a spare from an old tool cabinet, I'll have a look
Fri, 25 Nov 2022 13:08:14 +0000
150 VBB
150 VBB
Fri, 25 Nov 2022 13:08:14 +0000 quote
Bezel is about 3-4mm tall vs 1-2mm... but it works great and looks "period correct"-ish.
Fri, 25 Nov 2022 13:09:12 +0000
'58 VBA '79CT90
'58 VBA '79CT90
Fri, 25 Nov 2022 13:09:12 +0000 quote
My aftermarket lock lets me remove the key in either position.
Fri, 25 Nov 2022 13:23:46 +0000
VBA1T
VBA1T
Fri, 25 Nov 2022 13:23:46 +0000 quote
A link maybe to your model ?
Fri, 25 Nov 2022 15:06:56 +0000
'64 Motovespa 150S (177) , '66 Allstate SF, '65 VBB, '66 180SS
Fri, 25 Nov 2022 15:06:56 +0000 quote
I'd also like to know. That is an annoying feature.
  DoubleGood Design
[ Time: 0.0285s ][ Queries: 6 (0.0050s) ][ Debug on ][ 277 ][ Thing Two ]
