@colinbelgium avatar
VBA1T/Px200 iris
VBA1T/Px200 iris
Hi, going from a 3 to 4 speed engine on my VBA, I purchased a 4 speeds tube (I didn't even have any shifting tube anyway...) and I have an issue...
The tube can't reach its 4th position, the clutch cable is in the way.
Repro shit, again...
I can go from -1 speed up to 3, which makes me think the windows are not align properly. I could go like stetting the neutral position on 1st mark as I can easily pass down the 1st gear position, but then the 3rd mark on the tube would be 4th gear
The solution seems to be a slight clockwise rotation of A on the B axis
Is that possible ? It looks to require massive brute force ! Or maybe heating with the torch ?
Or could I grind a piece of the window ?
Thanks !
That's strange. I have a 3 speed shifter on a 4 speed bike and have no issues at all.
Probably easier to grind the window a bit I'd think
@safis avatar
@safis avatar
Is this one of the "Premium" parts SIP sells?? If yes, they're made in Vietnam that's why they're shit…
As said, easier to enlarge the windows…
VBA1T/Px200 iris
VBA1T/Px200 iris
@ray8 avatar
@ray8 avatar
ColinBelgium wrote:
Remarque 3...
"You fix it."
Get the short shifter adapter(?):
https://www.sip-scootershop.com/fr/product/rouleau-d-embrayage-tete-de-direction-sip-short-shifter_13979461
You could also relocate the mark on the headset. You should have plenty of space towards 1st with that tube as it is. 1st will be a bit high on the lever.
[ Time: 0.0235s ][ Queries: 3 (0.0031s) ][ Debug on ][ 313 ][ Thing One ]
