A lot of you have probably been here.
Sometime after buttoning the transmission back up it occurred to me I didn't check the belt direction on installation. Facepalm emoticon
Nothing to worry about?
Impending implosion?
try it and let us know. I look forward to the photos if it is a bad thing
It has been impressed upon me that belt direction is important. Enough that, when in your situation, I have taken the transmission back apart again.
That said, you've got a 50/50 chance here.
actually maybe Schrödinger would have some handy advice
So it won't fail (or not fail) until you take the transmission cover off again?
you can't be sure if you really did install it backwards, maybe your memory is faulty or maybe even though you forgot to pay attention you were lucky and got it correct anyway
@oldschooot avatar
@oldschooot avatar
Last night, I couldn't remember if I'd locked the passenger door on my Silvertomatoe 1500....so I slipped my sneaks on and went out to check 'em, in my Y-fronts.
I found that the door was locked.
So, if I were you...I'd put some pants on and go check that belt.
I slept better, after I warmed up (it was 28°F last night)....and so will you🙃
@max6200 avatar
2006 GTS 250
@max6200 avatar
2006 GTS 250
I myself strongly advise you to take the transmission cover off and locate the arrows and get your cell phone and take a picture. No take two pictures just in case you didn't push the right button first time. And don't forget to come back with a full report.
@phaskins avatar
2006 250ie
@phaskins avatar
2006 250ie
Just remember belts spin in the opposite direction in the Southern Hemisphere.
Picard emoticon
Great. I feel better after finishing my exhaust install and forgetting to tighten my axle nut. One of several procedures that got done over.
Peace of mind is a good thing....and piece of mind is 4 little bolts and one big nut away.
@touring300 avatar
@touring300 avatar
Don't worry, it's age related, a bit like belt wear.
@rrider avatar
@rrider avatar
Hmmm....I've always thought the rotation direction is marked just to help re-installing the same belt again = not to change the direction for a used belt, BUT, now that you mention this....
No help, sorry.
Follows this with interest Popcorn emoticon
@jah avatar
Piaggio MP3 250'2007
@jah avatar
BTW here's another thing everyone should know.
You never want to tighten the rear axle nut AFTER you've put the brake pads back to their working position. Always do that BEFORE squeezing the lever.
You don't wanna know how I came to this.
ummm ... this ain't making sense to me. I squeeze the rear brake to hold the wheel while I tighten the nut (clutch lock tool doesn't fit my malossi clutch)
@waspmike avatar
@waspmike avatar
Depends where you put it when you took it off.
_ Take belt off lay it on the floor. As long as the front of the belt is pointing forward it will be OK when you pick it up and put it back on.
As long as you pick it up the same way you put it down....
[ Time: 0.0137s ][ Queries: 3 (0.0068s) ][ live ][ 343 ][ ThingOne ]
