@billrush avatar
@billrush avatar
On my 2022 Sei Giorni I want to find the Turn signal Relay.
I'm told it's behind the panel shown below on the upper left side leg shield.
Further that you cut the small tabs which hold the planes in place. Cut the connecting strips of plaSTic CONNECTING POINTS, and lies hidden the relay.
So, cut the 7 tabs and the plastic (which says "relay here") is removed forever. And you have access to the relay.
PS, I've seen exactly this on a 2022 GTS 300
Can this be true? Why do it this way? Thanks
Access port ( I think) to relay on 2022 sei Giorni
⚠️ Last edited by Billrush on UTC; edited 1 time
2019 GTS 300 HPE w Malossi
I don't know why the cut outs aren't already cut out but you'd need to cut them out for fitting some accessories like usb charging ports.
and yes the flasher relay is up in there, not sure how easy to reach with your hand but I think I saw someone say they could reach it. Small hands?
pic from workshop manual
@cdwise avatar
GTS 300, Buddy 125
@cdwise avatar
GTS 300, Buddy 125
Yep, it is behind that panel. I had to cut it out on 2018 to install Scooterwests audible turn signal relay and extra power point for my GPS.
@touring300 avatar
@touring300 avatar
Robot covers how he does it starting at 5:00...
@billrush avatar
@billrush avatar
Thanks Touring300! It's great to see Robot cut that panel out! You found the video, copied the link and told me the time to look. Very nice of you!
The only problem with watching that video is that I really want the LED smoked out flasher set. Would look great on my Sei Giorni! But $250! Yikes!
Billrush wrote:
...smoked out flasher set. Would look great on my Sei Giorni! But $250! Yikes!
Here you go. 8 bucks.
https://www.ebay.com/itm/185319887802
@billrush avatar
@billrush avatar
What workshop manual do you have? I have the parts list but should have the manual.
I should have followed up that I did cut that panel out and found the relay. I used an LED relay that beeps I found on eBay for $7.49.
Works great and the beep is LOUD but adjustable.
"2 Pin 12V Beeper Motorcycle Indicator Flasher Relay Turn Signal LED Blinker"
Indicator relay.  Have used on 3 different Vespas
That's from the sei giorni manual
https://manuals.wotmeworry.org.uk/Vespa/GTS%20300i%20HPE/
@billrush avatar
@billrush avatar
Steelbytes:
Thanks a ton! Nice site!
[ Time: 0.0106s ][ Queries: 4 (0.0043s) ][ live ][ 343 ][ ThingOne ]
