Hi
ive just finished rebuilding and installed a vespa p200e engine and its making a ringing sound coming from around the flywheel. https://youtube.com/shorts/TBV7aam5Tvw
Vespa T5 classic 1994 and 1980 Vespa p200e
Posts: 412 Location: Burnham on sea, Somerset England |
Hi
ive just finished rebuilding and installed a vespa p200e engine and its making a ringing sound coming from around the flywheel. https://youtube.com/shorts/TBV7aam5Tvw |
Posts: 2475 Location: NYS |
2007 Stella 225
Posts: 3547 Location: Rochester, Minnesota |
shepys wrote: Sorry guys I've changed the privacy so you should see it now |
2007 Stella 225
That almost sounds like something is rattling? Was motor completely torn apart for rebuild? Top end rebuild? Clutch replaced?
Take off the shroud and see if it continues. could be the fan *barely* hitting the shroud.
Posts: 793 Location: Finland |
Stater and inside the flywheel looks good so I got lucky this time. Lock tight will do the job.
Not all good yet one of the screws what holds the stator plate keeps turning. The hole thread is isn't good. Lock tight isn't going to do the job I don't think.
2007 Stella 225
shepys wrote: Not all good yet one of the screws what holds the stator plate keeps turning. The hole thread is isn't good. Lock tight isn't going to do the job I don't think. |
2007 Stella 225
Little things like that can ruin your day. Just as you're buttoning up and ready to go for a ride. I had a stud strip on my front wheel hub and it took some days of figuring and fiddling to sort it out. Glad you got it sorted out.
