@ray8 avatar
@ray8 avatar
Saw this somewhere online.
Curious Douglas Vespa manual from the 50's.
Do booty-shake your bikes (#4)
Don't abuse your machine (#3)
@subetherbass avatar
#7 DON'T is pretty interesting.
@colinbelgium avatar
VBA1T/Px200 iris/VNB6T
#6 do also !
@bobo avatar
@bobo avatar
Where's the fun in #3?
@qascooter avatar
@qascooter avatar
Booty shake Razz emoticon ROFL emoticon
@psma avatar
125 GTR 1977, 50S 1975, GTS 125 Supertech 2021
@psma avatar
Venturi effect sucks petrol from the main jet well, mixing and rising the mix to the main orifice to the carb body. If you lean the Vespa to the right side to the point where the level on the jet well/fuel chamber is higher than this orifice exit, won't petrol flow by gravity into the crank case?
@ray8 avatar
@ray8 avatar
Explains the awkward/unbalanced side stands right there!
@r_fostoria avatar
'66 Sears Cruisaire Smallframe
@r_fostoria avatar
#4 Don't is interesting as well. I wonder what constitutes the correct RPM given a situation. I keep the revs up high when going heavy on the throttle, but while cruising or riding at lower throttle condition, I keep it in a higher gear. I figure high RPM + low throttle = less lubrication.
And that's why I spent so damn long designing a gearbox for Speedy... Once going, you are ALWAYS on the pipe. I even had to adapt my riding style & gear-change practices to make it work correctly.
[ Time: 0.0086s ][ Queries: 4 (0.0022s) ][ live ][ 343 ][ ThingOne ]
