@shepys avatar
Vespa T5 classic 1994 and 1980 Vespa p200e
@shepys avatar
Hi got a problem with my stator. one of the holes what the stator screws on has stripped. What thread kit do I need. Could JB weld work?
@gickspeed avatar
@gickspeed avatar
F* no. JB Weld is like ingrown hair on your taint that will not go away.
you will want to use a Helicoil (or similar in your country) for repair in this area. You can buy a Helicoil "kit" that would have the drill bit, tap, and helicoil inserter. I think m4, but measure first.
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
Ummm, I'd pass on the ingrown hair, even though I never had that experience. 😁
Is that a blind hole? Will he need a bottoming tap?
Might be a M5, be sure to look it up. I bought a bunch of stainless hardware and I thought it was another one of those odd Vespa sizes.
@greasy125 avatar
@greasy125 avatar
M5X14 .8 pitch
don't forget the flat washer and wave washer
parallelogramerist
parallelogramerist
What Greasy said on the pitch...M5x0.8
Look on the top of page 4 for my stripped stator plate screw holes Time-Sert fix... 1958 VB1 200 Wideframe scuttle bucket (Page 4)
@moto64 avatar
@moto64 avatar
Does that Time-sert leave a ridge on top , not allowing the stator to fit flush ? I think a Helicoil would provide adequate strength for this application.
@gickspeed avatar
@gickspeed avatar
Helicoil is the correct application.
2007 Stella 225
2007 Stella 225
Depends on time-sert, some have tools for flush mounting. I've used them on oil drain plugs in aluminum oil pans.
In this case, the best kit maybe what can be found locally.
parallelogramerist
parallelogramerist
All Time-sert kits come with a drill bit that countersinks the 'Sert's ridge.
[ Time: 0.0125s ][ Queries: 4 (0.0063s) ][ live ][ 343 ][ ThingOne ]
