1964 Vespa p90
1964 Vespa p90
SO I have a 1964 p90. I am looking for blubs.
Question 1: DO they make 6v led replacements that are any good for a 1964 vespa p90 and where to get them?
Question 2: There are two fastoon blubs in the tail light; one 5w & one 10w. I took them out but am unsure which goes on top? I cannot tell from the manual.
thank yo so much for your time.
Moved to Not-So-Modern.
@oopsclunkthud avatar
1:3
IIRC
10W goes at the top (brake light)
5W at the bottom (tail light)
this page has the bulbs linked:
https://www.scooterwest.com/tail-light-chrome-small-frame-078641.html
other shops would have them as well, it was just the fastest lookup for me.
@subetherbass avatar
6v bulbs are generally hard to find, but they are out there.
Nothing special about the Vespa ones, except that they are 6volt
@garncarz avatar
@garncarz avatar
If you have a balanced 6V AC system, you'll want to stick with incandescents. Bulbs are resistors. LEDs are diodes.
oopsclunkthud wrote:
IIRC
This is correct. 5w for the bottom running light and 10w for the top brake light
@chandlerman avatar
Innovator
239 Days Since Last Explosion
Innovator
@chandlerman avatar
This is what i was going to say. Or add a regulator to the mix.
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
Add voltage regulators, charging system working better than factory can blow bulbs also. A higher rpm motor could produce to much voltage and blow bulbs. A flywheel with stronger magnets than original design could blow bulbs.
@garncarz avatar
@garncarz avatar
1:3
Can't say I've ever had issues with the stock balanced AC setup even when revving the daylights out of it.
But once you start changing things...
[ Time: 0.0135s ][ Queries: 3 (0.0031s) ][ live ][ 343 ][ ThingOne ]
