I recently got a 2005 vespa lx50 2 stroke in silver.
It needs some work but I am happy to do it
I need to change headlight bulb. EU version so I believe that means it's a 35/35W bulb as opposed to the US 60W.
When ordering the parts I need I also ordered this to use as the headlight bulb as it caught my eye.
https://www.sip-scootershop.com/en/product/bulb-osram-cool-blue-intense-12v-60-55w-socket-p43t-h4_57305120
I just noticed it is 60W and I have heard of other people's housings melting because of the heat, I know the US version is 60W so is this ok to use or should I buy a stock one instead?
Should I get an LED kit for the headlight?
There is also a small bulb beside the headlight so if I out the new blue one in I need to change the small one too, what type of bulb is used for this and should I go LED for it instead?
I'm going to change all of the dash lighting so what type of bulbs are they and should I go for LEDs instead?
For the rear tail and break light I just bought to original bulb because it has the two filaments and I didn't know if the LED would go brighter for the the brake.
If anybody knows if an LED works should I get one?
My tail lights are all good but should I change them out for LEDs?
