@nelluch125 avatar
1981 Vespa P200e, 1985 Vespa PX125e, 1985 T5, 1971 Sprint Veloce
@nelluch125 avatar
Hey all,
Just debating with a friend about the specifics of an engine swap into a v90.
He states the 4 speed ET3 engine won't switch to 4 gear in a v90 chassis bc the shifter tube won't allow you to switch past 3rd gear.
I disagree but I really don't know for sure.
If I were to compete this engine swap, would I need to change the shifter tube from 3 to 4 speed as well?
Thanks for your input!
Pretty sure-o your friend is wrong-o.
Resisdent cool guy Poi Dog swapped a pv125 engine into his 90 frame/headset and it shifts to 4th with no issues at all. Shift tubes are the same to my knowledge. Only issue would be if it's a pre 66 90. But, that has to do with the engine spigot that goes through the frame, not the shifter.
@nelluch125 avatar
@nelluch125 avatar
I figured as much!
Thank you!
Does anyone else have any references that verify this? Thanks so much.
@finyoshi avatar
@finyoshi avatar
Friend of mine also has a 125 4-speed engine on his 90 frame so no issues there.
@gickspeed avatar
@gickspeed avatar
The only issue you might have is trying to take out the spark plug.
@greasy125 avatar
@greasy125 avatar
like others said, it'll fit. if it's early small door getting at the plug is a trick but doable. just paint an extra dot on the shifter tube.
to note, you'll probably want to run new shifter cables-- at least inners when you do it.
[ Time: 0.0079s ][ Queries: 3 (0.0017s) ][ live ][ 343 ][ ThingOne ]
