Et2 lx50 genuine stella 150 90
Any ideas on a replacement battery for my 1973 90?
Does it need the battery?
I'm also looking for a carb kit
@gmontag avatar
1964 GS160, 1966 Sears Bluebadge (90SS replica)
@gmontag avatar
I don't think you need a battery. What's under the left panel? A battery was typically to power the lights when the scooter was off but the key in the ACC position. It was a US DOT safety thing. I don't even see a key on your headset.
Carb rebuild kit:
https://www.scootermercato.com/Scooter-Parts/Carb-Gasket-Kits/CG16-KIT_2
I alternate between mercato and scooterwest. Wait till you are sure of what you need and make one big order rather than 5 small ones.
@brok3nr0b0t avatar
'71 Sprint Veloce
@brok3nr0b0t avatar
'71 Sprint Veloce
You can find the appropriate battery and a rebuild kit from quite a few online places. See here:
https://modernvespa.com/forum/post1515158#1515158
I always start with the US shops and then if I can't find what I need, go to the European ones.
Good luck!
Would the bike be a 12 volt or 6 v
@greasy125 avatar
@greasy125 avatar
it should be a 6V but anything is possible and could have been eliminated, changed or upgraded, it might be printed on the side too.
show us a pic!
btw: 3 caps on top usually means 6V and 6 caps 12V
It's a 3 cap
Should I keep this battery?
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
I would replace it with an AGM style battery, it's not vented and saves on corrosion around battery or vent tube. You can see what looks like corrosion was painted over with black paint in background.
Just throw it out, not buy a new one, and convert to non-battery. Apparently, it's not too difficult, but don't ask me how to do that.
[ Time: 0.0100s ][ Queries: 4 (0.0037s) ][ live ][ 343 ][ ThingOne ]
