@captainkilljoy avatar
vespa lx 150 2008
vespa lx 150 2008
hi, i have problem to start (electric start or kick start) my vespa when weather is cold, the indicator is my turn signal lamp doesnt on. but when the weather turn warm or hotter my vespa normal like nothing happened.
anyone have the same experience?
or
anyone know the solution?
thank you
@seamus26 avatar
@seamus26 avatar
Hard starting in cold weather sounds a lot like valve adjustment, but your indicators not working sounds like electrical.
I don't know much about a 2008 LX, but do the blinkers normally work without the bike running?
vespa lx 150 2008
vespa lx 150 2008
the blinkers works normally if weather turns warm or hotter, i check the blinkers first before i start my vespa, if the blinkers on, my vespa on too. it sounds weird but this happen to my vespa.
How is your battery?
vespa lx 150 2008
vespa lx 150 2008
i replace my battery 5-6 months ago.
@slowpoke avatar
1952 allstate (early), 1958 allstate, 2009 S150, 2001 ET2
@slowpoke avatar
What does your blinkers have to do with it? Could this be an electrical problem and nothing to do with the starter? Does the engine crank over when you try to start it? With the Kickstarter is there good compression?
Need more details to help you.
vespa lx 150 2008
vespa lx 150 2008
the blinkers just indicator i found when my vespa wont start in cold weather.
in the morning or when cold weather i put my key in and then start my vespa with electric starter the engine crank but my vespa wont start. and then i check my blinkers, my blinkers off.
when weather getting warm or hotter my vespa on like nothing happen and i check the blinkers on too.
now (in the morning or cold weather), i always check my blinkers first is it on or off before i start my vespa, when blinkers off my vespa wont start, if blikers on my vespa on too.
i'm sorry for my bad english, hope you understand
Did the problem start then?
vespa lx 150 2008
vespa lx 150 2008
No, my vespa had this problem 2 months ago
@seamus26 avatar
@seamus26 avatar
If it's cranking and won't start in cold weather it could be two things. (Probably more, but these are the two I can think of.)
1. Valve adjustment
2. Battery can't handle the cold
I have seen a proper valve adjustment make all the difference in cold starts. I've also had batteries that just didn't have enough oomph to start the bike when the weather got cold.
One way to check is hook a charger to the battery and see if an additional 12 amps will start the bike. If it does, then it could just be the battery.
I switched my Chinese bike over to a lithium battery and never had any starting issues afterward.
What makes me think it isn't battery is the kick start is also not starting the bike.
An LX generally won't kick start with a bad battery.
vespa lx 150 2008
vespa lx 150 2008
1. Valve adjustment
i will try it, thanks for your advice
[ Time: 0.0101s ][ Queries: 3 (0.0033s) ][ live ][ 343 ][ ThingOne ]
