Hi all
I got my hands on a sound bomb min horn to replace my horn as its crap.
I think the sound bomb mini is DC. My vespa T5 is AC.
I tried installing it but it didnt work.
Is there a converter or something i can do with the wiring.
Vespa T5 classic 1994 and 1980 Vespa p200e
Posts: 412 Location: Burnham on sea, Somerset England |
Hi all
I got my hands on a sound bomb min horn to replace my horn as its crap. I think the sound bomb mini is DC. My vespa T5 is AC. I tried installing it but it didnt work. Is there a converter or something i can do with the wiring.
2007 Stella 225
Posts: 3547 Location: Rochester, Minnesota |
Website says it's 12 volts 5 amps, your going to need an AC to DC converter capable of more than 5 amps or 60 watts. Not sure original horn wire will support that kind of amp draw either, It's the same as a 60 watt high beam headlight bulb.
Wiring diagram says T5 regulator is 80 watts max. If you live in a country such as the US that requires a front running light on at all times a low beam headlight is 30 or 35 watts, then tail light and anything else on may leave 40-50 watts maximum unused. You could press horn button and blow main fuse if you have one. https://denalielectronics.com/products/tt-sb-10200-b Something like this https://www.superbrightleds.com/power-supplies/voltage-converters-reducers/12-24-vac-to-12-vdc-voltage-converter-24-36-vdc-to-12-vdc-reducer-module-5a-max-output-5-amps Wiring diagram T5 MK1 Wiring Diagram Going to have to make sure wiring from AC source is a large enough gauge or diameter to support that much current draw. If I were actually going to actually go through all of this for a horn, I'd replace horn with a 12 volt AC relay or a DC relay with a small AC to DC converter with enough power for a relay. Then run all new proper gauge wire to relay, converter and horn. |
Posts: 5108 Location: Australa, Mate |
2007 Stella 225
SubEtherBASS wrote: Use dedicated wires & add a Bridge Rectifier Mount By front wheel. |
Posts: 5325 Location: Florence, OR |
Christopher_55934 wrote: WTF is that! |
I also have one on AnaKey, but had to point it down a bit, as would fill up with rain!
It's just a 60's car horn
Toot-TOOOOOOTTTT
Nedminder
Posts: 5009 Location: california |
Nedminder
shepys wrote: Hi all I got my hands on a sound bomb min horn to replace my horn as its crap. I think the sound bomb mini is DC. My vespa T5 is AC. I tried installing it but it didnt work. Is there a converter or something i can do with the wiring. Not many bikes will have wiring setup up for that horn. Even when I changed my wiring to DC on my PX200, still needed a smaller horn. Tried your exact horn on a Yamaha TW200 and didn't work. Most stock motorcycle horns have a much lower amps requirement. |
Posts: 1242 Location: Lakes Region of Maine |
I use the Nautilus horn mounted on my rear rack. The package has everything and it plugs right into my existing horn button Plenty loud.
