2001 Vespa ET2
2001 Vespa ET2
I went through the Fabio thread and ended up with this:
7.7g rollers (average)
98 main jet
70cc kit
17.5 carb
Leo Vince touring exhaust
tighter clutch springs
Malossi variator
It seems a bit sluggish to me and it takes me a bit to hit 40mph. Almost feels that I'm at WOT when I'm only around 3/4 throttle. I don't really hear any difference in the rev's after 3/4. Any suggestions?
need more mirrors :)
@oscarsass avatar
@oscarsass avatar
98 main jet
70cc kit
17.5 carb
Malossi variator
Roller weights will depend on the year of your bike. Later ones used lighter rollers from the outset AFAIK... but you have a Malossi variator, so that throws my knowledge off a bit - not sure what their 'factory equivalent' weight would be.
I went from 6.4g factory, to 5.7g (in a standard variator). 2001 bike.
If you have a cast iron 70cc kit (and standard airbox), I'd say that a 98 main jet is way too high for use with a 17.5 carb and leo vince touring exhaust. Try working your way down to 78 instead.
Mine runs fine with a mid-70s jet, combined with the 70cc cast iron kit and single layer malossi filter (in a standard airbox), and a Tecnigas Silent Pro exhaust (which isn't too dissimilar to the Leo V Touring exhaust?).
Also check your torque driver moves smoothly, and that your belt is within spec.
2001 Vespa ET2
2001 Vespa ET2
Thank you so much. Gonna try these adjustments and see where it takes me
@outsider avatar
ET 50 GTI250ie Sprint 150
@outsider avatar
You should have just left it alone I have stock ET2 with exhaust that will hit 48MPH.
[ Time: 0.0126s ][ Queries: 4 (0.0064s) ][ live ][ 343 ][ ThingOne ]
