Hi guys,
I fitted a 24/72 primary together with the 102cc Pinasco, 1st and 2nd speed will be much more fun and usable. Original on my 75 smallie is way too short 14/69.
Which 3rd and 4th "shorter" gear options do I have, in combination with the input shaft? My gear cogs are 58, 54, 49 and 43 tooth (input shaft 10, 15, 21, 26). I will have to change 3rd and 4th to i.e. 50, 46 … and then which input shaft do I need to go with them?
I have one input shaft 10, 14, 18, 20 - 4th doesn't even touch the 43 cog. Will a 46 4th cog work or the input shaft has to be something like a 10-14-18(20?)-22 with a 50 3rd and a 46 4th ?
Sorry so many numbers and questions, surely they're simple and clear for people used to tune up smallie engines…
