Old douglas ..smallie with polini 115..super with nasco 177
Working on a split headset vespa with square speedo The new speedocable inner is too big to lodge into back of speedo unit.Did i get the wrong one..???fits sweet at hub end....ie are there different size speedo inner cables at speedo end?
Update already .the cable fits on another speedo of same kind.sooooo suspecting piece of broken cable up inside preventing new one entry.If i dismantle the speedo will i have acess to the other side and thus be able to maybe drive it out...or upon seeing the other side of the inner cable square drive ,will it be closed over ,negating the fckn process?
Have you tried a magnet?
@hec_in_omaha avatar
1980 P125X US Spec
1980 P125X US Spec
Do you still have the Speedo cable that you're replacing? If so you can inspect the Speedo end and see where and how it broke. This way you can come up with a plan to extract the stuck piece. I am assuming the cable end is made by pressing a round spiral wound cable into a square shape at the ends instead of a square sleeve attached the end. If this is the case, you may be able to use a small sheet metal screw and screw it into the broken piece and pull it out it pieces.
Good luck!
Hec
Magnet and screw didn't work..
More swearing needed
I will buy an o ring pick and try .then its going in the parts bin for long-term storage
[ Time: 0.0095s ][ Queries: 3 (0.0037s) ][ live ][ 343 ][ ThingOne ]
