Vespa gts
Vespa gts
Keeps bogging out. Keep having to start it over and over. Still bogging. Please help???🌧️💦
@jkj-fz6 avatar
@jkj-fz6 avatar
How does it run when it's not raining?
Vespa gts
Vespa gts
It run fine after it dries out but takes a day after it rains. Or I just keep starting it over and over. Afraid of killing the starter.
@jkj-fz6 avatar
@jkj-fz6 avatar
Try spraying WD-40 on the spark plug, spark plug wire, and the coil. If that helps it's probably only temporary, so you might think about replacing those components.
Also, check that the battery connections are clean and tight.
Vespa gts
Vespa gts
Thanks I'll try that. Will keep posted
@max6200 avatar
2006 GTS 250
@max6200 avatar
2006 GTS 250
Do you have a windscreen?
@petercc avatar
Piaggio Beverly 300 ie - 2012
@petercc avatar
I once had a similar experience with one of the bikes long time ago.
As long as the engine was dry, no problem, but when wet it ran irregularly or even stopped completely.
It was a crack in the spark plug connector. When wet the spark took the easy way directly to mass. A new connector solved the issue.
Vespa gts
Vespa gts
Thanks I'll ask Brooklyn Vespa about that when I bring it in. 👍🏽
@kshansen avatar
GTV300 (wife's)
@kshansen avatar
GTV300 (wife's)
And be kind to others here and report back what you find.
I'm guessing it is a bad spark plug and or spark plug wire end.
[ Time: 0.0093s ][ Queries: 3 (0.0032s) ][ live ][ 341 ][ ThingOne ]
