Vespa gts
Vespa gts
Won't run in rain
@max6200 avatar
2006 GTS 250
@max6200 avatar
2006 GTS 250
Oh ok... How about in just a drizzle? How does it behave then?
@kshansen avatar
GTV300 (wife's)
@kshansen avatar
GTV300 (wife's)
Well with such a good list of information I would have to say an ignition problem.
Bad spark plug, bad end on spark plug wire, bad spark plug wire, bad ignition coil, or bad what ever sends juice to the coil.
@dooglas avatar
GTS 300ABS, Buddy Kick 125
@dooglas avatar
Going to have to tell us a little more. Do you store the scooter outdoors. Does it have a cover? Describe the symptoms. Does it turn over? Does it start? Does it run, then stall? Other symptoms?
@jkj-fz6 avatar
@jkj-fz6 avatar
@kshansen avatar
GTV300 (wife's)
@kshansen avatar
GTV300 (wife's)
JKJ-FZ6 wrote:
That's one of the problems when multiple post on the same topic are created. One can try answering to one of them but no one sees it when they see the other post.
I realize DG 2012 is rather new here so hope this does not continue! I know that it can be a bit confusing because until someone answers the first post it might look like the post never went through.
@max6200 avatar
2006 GTS 250
@max6200 avatar
2006 GTS 250
I'm just having fun
Locking this one as there is a duplicate with a better title.
[ Time: 0.0105s ][ Queries: 5 (0.0030s) ][ live ][ 343 ][ ThingOne ]
