@nelluch125 avatar
1981 Vespa P200e, 1985 Vespa PX125e, 1985 T5, 1971 Sprint Veloce
@nelluch125 avatar
Hi again,
Does the piston ring gap need to change based on the size of the cylinder?
I understand that 0.4mm is the standard gap for a piston rings for a p200 standard cylinder.
My question is: does that gap need to change if I have an oversized cylinder? (In my case 2nd OS).
Thanking you in advance.
N
@mjrally avatar
@mjrally avatar
No change. You'll get oversize rings with your oversize piston. Keep it the same .4mm gap and youre good to go!
@nelluch125 avatar
@nelluch125 avatar
Ok!!! Wonderful!
That was easy!
Thank you.
[ Time: 0.0100s ][ Queries: 3 (0.0036s) ][ live ][ 343 ][ ThingOne ]
