@billrush avatar
@billrush avatar
I just noticed that in official photos of Vespas by Vespa, they show the rear rack up. I always thought the first thing you do with a rear rack is buy a trusty clamp and put it permanently in the down position where it's ready for use?
Why even have it folding in the first place?
"Takes a deep breath and pushes submit"
@germangtsdriver avatar
Vespa GTS 300
Vespa GTS 300
The installed springs hold the folding carrier (in the best case) rattle-free in an upright position.
Folded down, it stands (depending on the model) possibly over the back (possibly bad when stored in garage or bad when maneuvering).
If you want to have him permanently folded down:
1. for the original folding carrier there is a small (overpriced) plastic clamp (number 623576), is unfortunately often stolen / lost
https://www.sip-scootershop.com/en/product/clip-piaggio-luggage-carrier-rear_PI623576
2. cable ties (There are also reusable cable ties) OR Double sided velcro
3. on some models, the springs can be inserted upside down, then the flap is permanently pressed down.
Imho this belongs upright and is only folded down for use
@shebalba avatar
@shebalba avatar
I have had instances where the cargo I was transporting secured better with the rack in the up position, utilizing the length of the rack when vertical.
@touring300 avatar
@touring300 avatar
I guess it's just down to personal preference but I prefer the look of the rack in the folded away position unless it's in use, the same with the front rack.
@kawi_girl avatar
Vespa GTS 300
@kawi_girl avatar
Vespa GTS 300
I agree about personal preference. I like to keep mine up when not in use as well. Often I keep a Nelson-Riggs day bag on it though, so it is usually down.
@dooglas avatar
GTS 300ABS, Buddy Kick 125
@dooglas avatar
I agree that this is a matter of personal preference. Having said that, I do think the folding rack looks good in the up position.
@boraxman avatar
GTS250
@boraxman avatar
GTS250
Flipped spring on mine first week I had it for rack down...never looked back.
@duck_dodgers avatar
2016 GTV
2016 GTV
^^^^^^this^^^^^^
Flip the springs. 15minutes tops.
Rack stays down.
Red 2016 GTS 300. Marrone etna 2012 GTV 300 Vie Della Moda. Maui Blue 1977 Suzuki A50P (AP50)
In the folded position when not in use
@cheshire avatar
GTS (sold)
@cheshire avatar
GTS (sold)
Up or down?
"Well, since I'm pointed that way, I guess down."
She chose down!
She chose down? Hah!!
"Was that wrong?"
Too late now!
:deeper into the labyrinth:
I prefer down, mainly because I use the rear rack frequently. Otherwise, I think my choice would be based on which way didn't rattle on bumpy roads.
Six, half a dozen, or the other for me.
@shebalba avatar
@shebalba avatar
Cheshire wrote:
Up or down?
She chose down!
"Was that wrong?"
Too late now!
'Nooo I say allo, but that's close enough.'
Not sure if we'll be helping hands anymore if go off into this tangent.
@max6200 avatar
2006 GTS 250
@max6200 avatar
2006 GTS 250
I like both looks. I think whoever engineered that rack was a genius.
Just put a topcase on it.
yup, so good that with the weight of a topbox and driving along bad roads broke the springs on it. I had to use thick zip ties to stop it rattling even when it was held down by the topbox
@adri avatar
Atypical Canadian
Atypical Canadian
@adri avatar
First thing I did was put two small zip ties to hold the rack down on the every day errand runner. It didn't make sense spending money on a clip when two zip ties can do the job and I have about 600 zip ties of all lengths and colors in the garage.
Buuuut... it also doesn't make sense to have two zip ties doing what the original hardware can do, so can someone please show/teach us the spring flip trick you guys are mentioning?
@cheshire avatar
GTS (sold)
@cheshire avatar
GTS (sold)
https://modernvespa.com/forum/post840670#840670
Here ya go, Adri.
Another option is getting the clamp for the Vespa topcase that bolt the rear rack down. Gimme a moment to dig up the link.... https://www.scooterwest.com/topcase-fitting-plate-for-gt-gts-top-case-to-folding-rear-rack-623699.html
Edit to add: link to folding rack OEM fitting plate thingit. I used this for a while with good results. I also reversed the springs before using this with good results. I think I moved on from reversed springs when I got a topcase that stayed installed 24/7.
⚠️ Last edited by Cheshire on UTC; edited 2 times
@max6200 avatar
2006 GTS 250
@max6200 avatar
2006 GTS 250
Not a fan of the top box here sorry
@mopmop avatar
2017 GTS300 'Beauty'
@mopmop avatar
I first tried the folding rack with the top box: I didn't trust it at all, so I quickly removed the top box again. Anyone with a little bit of physics knowledge can see that the lever effect just screws it up when putting a top box on it. Unless the top box is mostly empthy and you only use it to secure your helmet after riding. I don't understand why Piaggio offer the folding rack as a top box support.
I now use the fixed rack and it makes all the difference: sturdy, logical construction and it gives me faith that whatever is on it, still is after a bumpy ride...
@chrisfromcle avatar
I have a top case with a fixed rack on the back. On the front, I use these to keep it down:
https://www.amazon.com/VELCRO-Brand-Cable-Ties-100Pk/dp/B001E1Y5O6/ref=sr_1_3?crid=1QT5AP4MQQRB2&keywords=wire+organizer+velcro+ties+small&qid=1671025232&sprefix=Wire+organizer+vel%2Caps%2C148&sr=8-3
Simple and cheap. Almost invisible.
Chris from CLE
Rack up
Rack up
Rack Down
Rack Down
Rack up when not in use, it just looks better IMHO
@shebalba avatar
@shebalba avatar
Chris from CLE
I started buying these years ago to deal with unsightly AV and power cables. They have become an essential go-to for so many applications. I keep a bunch in my pet warmer. I've even daisy chained them together in a pinch when needed to secure something larger.
Agreed. I keep my front rack up unless in use. I would keep the back one up too except that it is a fixed rack for a top case. I really don't prefer the look with the top case on. Since it is one bolt attachment, I mostly keep it in the garage until needed. Mrs. CLE requires the top case on to ride two up…
Chris from CLE
@desmo33 avatar
2016 Sprint 150, 1965 Li125 Special
@desmo33 avatar
The spring-loaded folding action of the rack can also be used to transport something like a jacket or blanket; the rack acts as a clamp to secure the load without the need for tie-downs.
@syd avatar
@syd avatar
Until I found helmet-strap extenders to use the nubs under the seat, I would strap my helmet on the folded-down rack. Otherwise, I liked and still do like it up, where it belongs.
@witch avatar
Moderatrice Strega
Moderatrice Strega
@witch avatar
I opted to set the rear rack permanently down on my GTV. I noticed that if I hit a hard enough bump, the rack would bang against itself in the up position, and make me concerned that I'd either hit or dropped something. I used it often enough, there really wasn't a point in having it up, anyway.
[ Time: 0.0117s ][ Queries: 4 (0.0040s) ][ live ][ 343 ][ ThingOne ]
