Hi, i'm about to 1st start my vba with an LML 150 5 ports engine.
What spark plug should I use ? The head accepts a long thread spark plug but SC references a short one (B8hs) for this engine.
What percentage of oil should I mix to petrol ? 2, 3, 5 % ? It is a new engine, is the mix different for breaking in period ?
Concerning the carb, what do you recommend as base setting for the carb mix and idle screws? I've heard 2 1/2 turns for the mix, no idea for the idle.
It is a 20/20 with factory jets
