@gickspeed avatar
@gickspeed avatar
Repaired a previous "repair" that was absolute trash. Why try?! They brazed it and just looked awful. Some real low-end stuff.
@greasy125 avatar
@greasy125 avatar
lovely work John.
it's funny how brazing something is so easy yet people can totally mess it up!
@ray8 avatar
@ray8 avatar
Pics of the other side?
Did you de-stress the crack?
@gickspeed avatar
@gickspeed avatar
Hook on the cowl appeared to be a coat hanger brazed on. I removed a factory piece off a bad chassis and replaced it.
parallelogramerist
parallelogramerist
Option B is to dig REAL deep in the bag of bodge tricks and simply screw the crack back together
i'd advise getting a tetanus shot before petting the legshield on this scooter
Evidence of a proper backwoods bodge fix with an 221v Ozarc welder
⚠️ Last edited by whodatschrome on UTC; edited 2 times
@qascooter avatar
@qascooter avatar
What a crack up... ROFL emoticon Facepalm emoticon
@ray8 avatar
@ray8 avatar
My single experience with that repair went as follows:
Repaired one side as you did.
Repaired the other side by cutting out a maybe 3" square at that weak point.
Thicker gauge plate. Shaped it using a vice and 3/8" rod. After welding it up I blended it out with flap disks to the original gauge. It isn't noticeable (see pic) and so far defeats that weak point.
It's been knocked over a few times since then on both sides.
My wife backed into it 1x.
Homeless guys-related knockovers 2x.
I "may" have put it on the side stand out of balance 1x.
Crack
Crack
No crack
No crack
@orwell84 avatar
@orwell84 avatar
Brazing used to be the popular for auto body, it's the first thing I learned. Gas welding was considered too hot for sheet metal, but actually works fine with a small enough tip and correct technique. I would love to get back into gas welding again, but the tanks are a PITA. I would probably MIG weld a legshield crack…spray and sculpt until good.
Very nice work by the way…
@subetherbass avatar
Don't you just bend the cowl around at that point before painting it, so when it falls over it's already bent to shape?
Plus, it is more aerodynamic
[ Time: 0.0131s ][ Queries: 4 (0.0069s) ][ live ][ 343 ][ ThingOne ]
