As the title says I am perplexed and don't know how to fix it. I tried replacing the bulb but to no avail.
The rear light only turns on while braking, but it is off while running
The rear light only turns on while braking, but it is off while running |
Are there 2 separate bulbs within the light unit itself? Or is it one single bulb that changes brightness when the brakes are pressed?
I'd start at the cheapest option first, which is buy another rear bulb on the off chance that the new bulb has been dropped at some point. After that, I'd buy a spray can of "contact cleaner". Unplug the connectors near the tail light, spray some in and then reconnect. Contact cleaner is a mild acid, so try and avoid getting any on the Vespa, and wash your hands immediately after - even if it feels ok in the moment, as it will irritate / burn if left. |
JakeM wrote: Are there 2 separate bulbs within the light unit itself? Or is it one single bulb that changes brightness when the brakes are pressed? I'd start at the cheapest option first, which is buy another rear bulb on the off chance that the new bulb has been dropped at some point. After that, I'd buy a spray can of "contact cleaner". Unplug the connectors near the tail light, spray some in and then reconnect. Contact cleaner is a mild acid, so try and avoid getting any on the Vespa, and wash your hands immediately after - even if it feels ok in the moment, as it will irritate / burn if left. |
It sounds like a double filament bulb. They usually go in and a quarter turn to the right. Try not to touch the bulb with your bare hands a clean cloth comes in handy.
Max6200 wrote: It sounds like a double filament bulb. They usually go in and a quarter turn to the right. Try not to touch the bulb with your bare hands a clean cloth comes in handy. |
SteveMster wrote: |
Igcetra wrote: this is the exact video that i followed, and the result was what i posted about: the light only turns on when braking, but not while its running |
Start by using a simple 12v tester to see if there is current to the bulb at the socket. Work from there.
Positive
Posts: 11521 Location: Hermit Kingdom |
Isn't the bulb a single filament brake light only? The running light is separate?
Positive
Posts: 4736 Location: Twin Cities, Minnesota |
Igcetra wrote: this is the exact video that i followed, and the result was what i posted about: the light only turns on when braking, but not while its running Aren't the running lights separate from the brake light on a 2016 Sprint? I would compare it with my Primavera but it's tucked away for the winter. |
Yeah. I think the running light is built in to the light housing.
OP there should be another wire coming in for that. |
2015 Sprint 150, 2018 GTS 300
Posts: 894 Location: SoCal |
Tailight bulbs are single filament on my 2018 Primavera and 2015 Sprint 150
both RT & LT rear running lights stay on but taillights only come on when braking, pretty sure this is how they are from factory. I'd also add first video rear running lamps are clear, both bikes of mine are red and come on when the scooter is on |
CaliforniaCruising wrote: I'd also add first video rear running lamps are clear, both bikes of mine are red and come on when the scooter is on |
JKJ-FZ6 wrote: I think that's because of the difference between Euro and US turn signals. The OP hasn't said where they are located.
SteveMster wrote: |
