Vespa Lx125
Vespa Lx125
Hi Guys, I have a 125LX automatic 2009, I was going around 60km yesterday and I heard a loud pop and lost all power, I thought I'd blown the tyre but, they are both fine, I pulled over and stopped. I turned the engine on and it runs but, it has no power and there was a smell like burning rubber, so I switched off and I've now got it home, does anyone have any ideas what may have happened, I have been having fuel problems I would have to squeeze the soft pipe under the seat a few times to get it started most days, it's recently had a new oil filter and oil change around 2 months ago. Thanks in advance
@fleece avatar
@fleece avatar
sounds like your drive belt if it's still revving, but not going?
oh, and Hi
@cosmos avatar
2009 LX 150, 2024 GTS Super
@cosmos avatar
Here is some information on belt change.
Vespa Lx125
Vespa Lx125
I thought it was something like a chain on a bike, what would the smell be from? Thank you for the answers so far
@fleece avatar
@fleece avatar
the belt is made of rubber
if you take the job on yourself, it'll need a good clean up in there
if you're not worried about a bit of spanner work, it's well worth buying the tools and DIY, it'll save you a lot in the long run as the belt and rollers need changing at regular intervals
Vespa Lx125
Vespa Lx125
Thank you, I'm definitely not a mechanic but, I have a friend who's away and can hopefully sort it when he's back, thank you all for the advice.
[ Time: 0.0101s ][ Queries: 3 (0.0020s) ][ live ][ 343 ][ ThingOne ]
