Hey all
Anyone in NY got a swign arm tool? I've got a GTV seized on real good and cant shell out the money for one and beyond my capabilities to build my own
Hey all
Anyone in NY got a swign arm tool? I've got a GTV seized on real good and cant shell out the money for one and beyond my capabilities to build my own |
The term swing arm is used in different ways on this forum. You mean the bracket underneath the exhaust? What are you trying to do?
I was able to borrow a standard 3 finger gear puller and after fiddling around with it for a bit make that work. A new bearing went on after all the carnage.
Posts: 46190 Location: Pleasant Hill, CA |
Crim wrote: Hey all Anyone in NY got a swign arm tool? I've got a GTV seized on real good and cant shell out the money for one and beyond my capabilities to build my own |
S150 '09, Beo 500ie '08
Posts: 1596 Location: Bermuda |
Posts: 12936 Location: Fond du Lac, Wisconsin |
Advance and other auto parts places often have free tool loans. IIRC I got a puller from Advance to pop mine off.
Sullivan County, but can drive a good distance around it. In the city a bit too
Juan_ORhea wrote: NY is a pretty big place, 54,500 square miles. Where are you? |
Exactly what i got in a bunch of varying sizes, but to no effect. The tip just kept digging into the end of the axle shaft.
jimc wrote: A set of pullers at Harbor Freight is very budget-friendly. |
Crim wrote: Exactly what i got in a bunch of varying sizes, but to no effect. The tip just kept digging into the end of the axle shaft. Not failed yet, though there's always a first time... |
I mean i had a 3' breaker bar tightening this puller and was tapping the end with a hammer, but i just felt i was digging into the axle shaft.
I was nervous i was gonna do damage to the gears jimc wrote: I put the axle nut back on loosely to help centre the tip, tighten up the puller pretty damn hard, then whack the end with a hammer. Not failed yet, though there's always a first time... |
You would likely just bend the scooterwest tool. Use the standard wheel puller and some good raps with a hammer. Tighten, hit, tighten, hit, tighten, hit.
I can see how a three-arm puller would have trouble pulling usefully on an off-center, asymmetric part like that. I also see the skepticism regarding the ScooterWest $45 tool.
I would definitely heat the aluminum part with a heat gun or propane torch (a hair dryer is not useful for this), and maybe try to rent a two-arm puller. I have found this two-arm brake rotor puller indispensable for asymmetric stuff like this, because you adjust each of the two pulling arms separately: https://www.amazon.com/OTC-6980-Heavy-Brake-Puller/dp/B004CGOGFS This device is capable of cracking a rusty, stuck brake rotor in half like a cookie, but there is no chance you'll be getting to that point on the swingarm. Agree that the shock force of the hammer on the tensioned puller will probably be the thing that pops it free. When you reassemble, smear some antiseize compound on the axle first. Not Loc-Tite, antiseize! |
