Vespa LX50 2T 2005
Vespa LX50 2T 2005
I have a vespa lx50 but the seat lock never locks, I only got it a few weeks ago so I didn't damage it, I bought it that way.
Do I need to replace this
https://www.sip-scootershop.com/en/product/cable-seat-locking-front-piaggio_PI653994
Or this
https://www.sip-scootershop.com/en/product/lock-seat-piaggio-seat_PI497457
Or both?
And how do I go about replacing it
@yellow300gts avatar
300 GTS supertech HPE
what you need to replace, comes down to whatrver is broken, but have you cheched if you can spray it with some lube???
Vespa LX50 2T 2005
Vespa LX50 2T 2005
I already tried that and it didn't do the job
The key in the seat turns but when pressed down it doesn't lock
@adri avatar
Atypical Canadian
Atypical Canadian
@adri avatar
Assuming you've already lubricated heavily and SMACKED and pushed down on the seat, hard, when you turn the key in the seat is it doing anything?
Vespa LX50 2T 2005
Vespa LX50 2T 2005
No
The guy I bought it from said the "key bit works, it's just the mechanism needs replacing"
So could that be the mechanism or the cable he may not be knowledgeable
It could be either for goodness sake - we're not there to look at it! Just eyeball it, work out how it should work, then you'll spot why it doesn't work.
@der_blechfahrer avatar
Just open the cover and see if the cable works the lever. If it does, maybe the pin/catch is broken.
Lever
Lever
Pin/catch
Pin/catch
Underside of pin/catch
If all of that works and isn't broken, loosen the seat (two bolts) and realign it.
Vespa LX50 2T 2005
Vespa LX50 2T 2005
Thanks very much
@max6200 avatar
2006 GTS 250
@max6200 avatar
2006 GTS 250
Remove the gas tank cover that will expose the locking mechanism. Put a couple rubber rings to raise the opening mechanism. That will fix your problem.
Max, have you looked at the pictures? This is an LX.
@max6200 avatar
2006 GTS 250
@max6200 avatar
2006 GTS 250
Facepalm emoticon
@max6200 avatar
2006 GTS 250
@max6200 avatar
2006 GTS 250
My bad. I shouldn't have been posting after two hour nap. Facepalm emoticon
[ Time: 0.0100s ][ Queries: 4 (0.0021s) ][ live ][ 343 ][ ThingOne ]
