Working on VNA Allstate. have the bearings seated on the crank, heated the clutch side case up, spit sizzling, put crank with bearings in freezer for about 20 minutes. Put the crank into case goes in well, but I don't think it's not fully seated, bearing is about 1/8 sticking out and crank doesn't go smooth. See pic where I am talking about.
How do I get this fully seated now?
Advise needed. Do I heat the case some more and try to shove it?
Cheers all.
