@shepys avatar
Vespa T5 classic 1994 and 1980 Vespa p200e
@shepys avatar
I got a clutch from Beepspeed but after installing with a 3.7 thrust washer its not working. clutch not working when in gear when pulling the clutch lever.
Vespa Clutch Unit P200, Rally 23 Tooth 7 Spring
Product Code: BD02130
1968 Sprint 150
1968 Sprint 150
Is your brass plunger functional?
@moto64 avatar
@moto64 avatar
Have you properly adjusted out the travel at the cable end before the plunger engages the plate ? Should be about 2-3mm at the handle bar lever.
@shepys avatar
@shepys avatar
Yes all spot on
@grumpnut avatar
'58 VBA
@grumpnut avatar
'58 VBA
Separate thread, same subject, op
Rusty new clutch
Return that rusty thing.
@shepys avatar
@shepys avatar
Was thinking about cleaning it up but it's new so yes I'm sending it back.
Jet Eye Master
Jet Eye Master
Good luck with that.
I hate the 7 spring type. If you can exchange it for a Cosa clutch. Fits the same but works better and longer.
[ Time: 0.0115s ][ Queries: 4 (0.0046s) ][ live ][ 343 ][ ThingOne ]
