primavera 150cc
primavera 150cc
Hi, I had my vespa services after it got knocked over, and the front left blinker won't blink, and the back left blinker won't turn on. They guy came and fixed it a month ago, but when I went to ride it today, they wouldn't work.
@jkj-fz6 avatar
@jkj-fz6 avatar
The first thing I would try would be replacing the left rear bulb.
primavera 150cc
primavera 150cc
Thank you. How do I do that? I wondering if it's a wiring issue cause also when it got knocked over the back light was fallen off
@jkj-fz6 avatar
@jkj-fz6 avatar
If I recall correctly (my Primavera is put away for the winter) there's one screw holding the lens in place. Remove the screw and pull the lens out, then you can get to the bulb. When you replace the lens be sure the slotted tab on the back catches the slot in the stalk. (I'm assuming you have the US style turn signals. If you put your location in your profile it helps.)
primavera 150cc
primavera 150cc
amazing, thank you- will try that now. Where do you buy your vespa bulbs from?
@jkj-fz6 avatar
@jkj-fz6 avatar
Can't help you there -- I've never had to buy a Vespa bulb. Maybe someone can give an equivalent that you can buy at a car parts store.
primavera 150cc
primavera 150cc
ah! it worked! The back bulk was look so I stuck it back in and now both blinkers are working!!!! Thank you for you help! Beep Beep!
[ Time: 0.0111s ][ Queries: 4 (0.0022s) ][ live ][ 343 ][ ThingOne ]
