gts300 super abs/asr
My gts300 super has ABS pump model number 1631. By the way, I'd like to order parts, but is the model number of 1630 compatible?
My gts300 is a 2015 super model.
Vehicle number starts ZAPM45202.
⚠️ Last edited by kokdongmen on UTC; edited 1 time
@germangtsdriver avatar
Vespa GTS 300
Vespa GTS 300
It's easier when you not shorten the SKU: 1C00xxxx
Search compatibility with SKU on SIP, ScooterCenter, easyparts or other resellers for BOTH SKUs.
I didn't understand
1c001631 / 1c001630 Is there no problem using both products ?
Vespa GTS 300
Vespa GTS 300
kokdongmen wrote:
I didn't understand
Can't tell you! I meant: check the compatibility of both items and then decide, in case of doubt I would rather choose the identical part number with the currently installed pump.
For 1c001630, relatively few but contradictory data can be found on the Internet. As it looks, no dealer carries this item (as a new part).
NOTE: as far as I know the installation and programming of the control unit must be done by a Vespa/Piaggio workshop
1980 P200E - GT 200 L - 2005PX150
Did you get the part? What was the issue u where having?
[ Time: 0.0099s ][ Queries: 4 (0.0029s) ][ live ][ 343 ][ ThingOne ]
