EDIT: here is someone else's similar Adding a light strip to a newer Vespa top case
⚠️ Last edited by SteelBytes on UTC; edited 6 times
2019 GTS 300 HPE w Malossi
Posts: 9419 Location: Batmania aka Melbourne, Aus |
Sadly the photo and video don't show the real brightness of the LED strip. I could take a photo in the dark but that's cheating.
Positive
Nice size and placement. I preferred the boxes with the lenses, even if they were fake, because it was a no-brainer as far as adding lights. But your application looks does look sharp.
Some construction pics
Making a bracket by bending some scrap metal
Brackets painted and covered in black cloth tape and screwed to the seat pad
Cable routing with connector so I can remove the box
Hacking into the wiring
⚠️ Last edited by SteelBytes on UTC; edited 3 times
Positive
This is the light I used. I chose to only wire the brake and not the tail or turn.
AU $4.61 45%OFF | Flexible 48LED Motorcycle Light Bar Strip Tail Turn Signal Tail Rear Brake Stop Bulb Lamp Brake Light SMD Motorcycle Light Strip https://a.aliexpress.com/_mrVgygm
Posts: 2178 Location: Lancaster, U.K. |
I would have thought that from a car driver's seated position the brake light strip would be partially obscured by the 'hump' of the top box lid?
Touring300 wrote: I would have thought that from a car driver's seated position the brake light strip would be partially obscured by the 'hump' of the top box lid? Putting it above / below the licence plate like I see many others do seems pointless to me. I did consider some sort of bracket to mount it at bottom of the box right at the rear but couldn't come up with a design I liked. Since it's a secondary I'll be content without 100% visibility. Edit: also remember the box is curved and the light is near enough to the peak of the curve ... Maybe more visible than you suspect? |
Posts: 2820 Location: Ohio |
Good project since many car drivers now watching their phones instead what is front of them. Any additional brake light rise (y)our safety.
Helmet brake light would be good add-on too. Now just searched Alibaba and they already made this under name "Motorcycle Helmet Turn Signal Light Helmet Brake Light for Night Riding Safety" |
SteelBytes wrote: Sadly the photo and video don't show the real brightness of the LED strip. I could take a photo in the dark but that's cheating. EDIT: here is someone else's similar Adding a light strip to a newer Vespa top case Bought the same LED module and wired it in as a stop/tail. Glued to my Givi base plate, so it remains on the bike if riding without the top box. 👍 PS the LED module slides inside of its housing, so had to centralise it after taking that pic. Now I have to do the ET2.
