When operating tilt switch sometimes works fine other times constant beep and won't lock suspension took of plastic the cable seems to stop working about 2 thirds of way switch off do reset then it works again cleaned wheel sensors topped up fluid new tilt switch wondering if battery is problem it's 11 years old
Thanks to be fair I've only had the bike a year and it's always started first time it was only when I checked date on battery and it said 2011 I realised it's probably original battery
Modern Vespa is a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for sites to earn advertising fees by advertising and linking to amazon.com All Content Copyright 2005-2023 by Modern Vespa. All Rights Reserved.
[ Time: 0.0223s ][ Queries: 4 (0.0018s) ][ Debug on ][ 276 ][ Thing Two ]
