@aa-gts avatar
HPE(2) 300 Super Sport
@aa-gts avatar
The 2023 Vespa HPE has three relay switches hidden in a small compartment inside the glovebox - does anyone know if one of these relays is for the turn-signals?
Better still, has anyone got a wiring diagram for the 2023 HPE300?
@touring300 avatar
@touring300 avatar
On the older 300's, the indicator relay is found behind the left knee pad, take a look in there first. The 3 relays in the glove compartment are probably the ones that used to sit behind the horn cover on the older models and have been relocated.
gts 300
gts 300
Hi, did you get this sorted?, fuse top row third from the left 5A is for the indicators but also other things, page 98 in the book you get with a 2023 vespa gts 300, Ian
GTS 300 2023
GTS 300 2023
This could be the thing you are looking for.. However, this might not be the normal turn indicator relay from older GTS (2022 and older).. [/img]
turn indicator module
[ Time: 0.0096s ][ Queries: 4 (0.0044s) ][ live ][ 313 ][ ThingOne ]
