Vespa GS150
Vespa GS150
Hi guys, I'm currently restoring a 150 sprint veloce and need to install new floor rails and centre mat. I'm a bit wary of installing the centre mat without the correct glue. Should I be using contact adhesive and do I glue down the side under the trim and fixing or just under the flat centre of the mat.
Any advise would be appreciated
I never used any glue at all. I just heated it up and installed.
I have used both contact cement and Shoe Goo. (Usually just a dab at the front and back of the mat.) I don't know that I have a preference. With either one make sure your mat is centered and put some kind of weight on top of it while the glue dries.
I have never put glue underneath the little side flaps. I just use the chrome trim to hold them in place.
YMMV
⚠️ Last edited by Birdsnest on UTC; edited 1 time
Vespa GS150
Vespa GS150
Thanks guys, I might give the contact adhesive a go
@grumpnut avatar
'58 VBA
@grumpnut avatar
'58 VBA
Contact cement. And bamboo skewers to keep it separated until you're sure and helps lay it flat, no bubble.
Vespa GS150
Vespa GS150
I used contact adhesive with wooden skewers, awesome idea! I let the glue go off and layer it with skewers and placed the mat on top, just pulled them out one at a time. Perfect result.👌
I think nothing is best to allow any water to drain out.
[ Time: 0.0108s ][ Queries: 3 (0.0034s) ][ live ][ 343 ][ ThingOne ]
