A 2008 Genuine Buddy 125 powered by a turbocharged GTS 300 engine.
If not, here's a glimpse:
In the ever increasing push to see where the edge was and answer the question NOBODY was asking about the GTS: How much boost will that thing actually take before something says enough???
Well for the sake of posterity I have the answer to that question. 25PSI.
I was out on a test run, made some changes to my wastegate setup that gave me boost control so OBVIOUSLY I cranked the boost to see where it ended up.
I made a terrifying run at full throttle and watched the boost gauge creep up to 25PSI when suddenly the power dropped. It dropped from madness inducing to just merely scary beyond all reason. I pulled over, and it was idling ok but still down on power. At that point I noticed that it was puking oil out the breather hose, which meant I had a serious blow-by problem. I rode it the mile home to the garage fine. It still was putting out mountains of power but not what it normally did...
I pulled apart the engine to confirm my suspicions. Cracked ring lands on the piston.
Yup. Not good.
Now this hasn't slowed me down any... Just yesterday I got a new Weisco forged piston installed and its back running. But to get any more power than I'm getting now I'm going to have to go for bigger injectors and E85 fuel. So for the time being I'll keep the boost down when running pump gas and enjoy my still huge power output... Ohh, on that note...
See it down there at the bottom? 53HP. And that was BEFORE the boost controller, at about 14PSI. Some back of the napkin math says that at 25PSI I should have right around 67HP.
More to come as this madness continues. Or I and my scooter explode in a ball of race fuel induced fire. One of those.
